Software Application Development eth0 speed on zedboard 3.6.0-xilinx
  • Subscribers 364 subscribers
  • Views 1214 views
hi all,
I'm testing the 3.6.0-xilinx package and I've some trouble with eth0 port: it seems that the autonegotiation doesn't work and is always at 1000/Full, even if connected to my 100/Full router.
I installed the ethtool (http://www.openmamba.org/distribution/distromatic.html?tag=devel&pkg=ethtool.arm) and tried to force it to 100/Full, but this is the result:
zynq> ethtool -s eth0 speed 100 duplex full
zynq> xemacps e000b000.ps7-ethernet: Set clk to 24999999 Hz
xemacps e000b000.ps7-ethernet: link up (100/FULL)
xemacps e000b000.ps7-ethernet: Set clk to 124999998 Hz
xemacps e000b000.ps7-ethernet: link up (1000/FULL)
it goes to 100 then back to 1000
does anyone knows how to fix this?
    the problem solved or not?
    As follows, the problem can be solved.
    modified the kernel source:
    linux_xlnx/drivers/net/phy/Phy_device.c
    at fuction genphy_read_status();
    line 902-907 are invalid. As followsuFF1A
    //ttif (bmcr & BMCR_SPEED1000)
    //tttphydev->speed = SPEED_1000;
    //ttelse if (bmcr & BMCR_SPEED100)
    //tttphydev->speed = SPEED_100;
    //ttelse
    //tttphydev->speed = SPEED_10;
    this maybe not the best solved method, but it can work
    hi,
    I solved my problems by loading linux-3.6-digilent and with some modification in the description files
    if anyone is interested I can share my files
  • fairuzamin
    0 fairuzamin over 12 years ago in reply to e14 Contributor
    Hi Roberto,
    Could you please send those files.
    I have tried hard the suggested fix here and hard coding the speed in this file but no joy yet.
    T
    pls send those files
