Software Application Development Whether can GPIO bind a pinctrl-single device?
  • Subscribers 364 subscribers
  • Views 667 views
aersean
aersean over 9 years ago
I fond pinctrl-single device in Xilinx document. So I want to use it bind a GPIO pin, and then control the pinctrl device. But I don't know whether this way is right.
if you know please tell me. Thank you!!
Best regards,
Aersean
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Aersean,
    Could you please refer me to the xilinx document in which you found the pinctrl-single device.
    --Josh
  • aersean
    0 aersean over 9 years ago in reply to jafoste4
    Hello Josh,
    Thank you at first.
    I was task for BPS, and I have never worked for device tree before. I only read some user guide for device tree, so I am a beginner for this.
    Now we have a new project that is research the ZYNQ-7000 serial. I have a PicoZed-7030 development board. I read the Xapp-1078. In this document, the CPU1 can't directly access GPIO ps pin (share resource). So I want to add a device into Petalinux, and access the GPIO ps pin.
    Last time, you give me some help for LED, it is success. In fact, I think we maybe need a general GPIO ps pin controller, so I found  pinctrl-single device. I hope use it can control GPIO ps pin input/output and get the interrupt when the level is changed.
    The document for  pinctrl-single is:
    https://github.com/Xilinx/linux-xlnx/blob/master/Documentation/devicetree/bindings/pinctrl/pinctrl-single.txt
    Thanks for your help!!
    Best regards,
    Aersean
  • jafoste4
    Hello Aersean,
    You may find more success asking this quesion over at the xilinx embedded linux forum.
    https://forums.xilinx.com/t5/Embedded-Linux/bd-p/ELINUX
    In the mean time here are some resources for you to start with:
    https://forums.xilinx.com/t5/Embedded-Linux/Accessing-PS-GPIO-through-Petalinux/m-p/679232/highlight/true#M15253
    https://forums.xilinx.com/t5/Embedded-Linux/Test-zynq702-gpio-on-ps/m-p/259680/highlight/true#M4581
    https://forums.xilinx.com/t5/Embedded-Linux/Zynq-PS-interrupt/m-p/516363/highlight/true#M10450
    --Josh
  • aersean
    Hello Josh,
    Thank you. I will reseach it again. If you have some suggestion please tell me.
    BR
    Aersean
