Software Application Development Access PL through Linux
  • Subscribers 363 subscribers
  • Views 232 views
Im a newbie to FPGA and Im working on a MicroZed 7010, I have generated a bootable image using PetaLinux.
I want to know if there is a way to access (or maybe test) the PL (or maybe its registers) through Linux??
Thx.
  • jafoste4
    0 jafoste4 over 10 years ago
    Hello Fourat.oueslati,
    I would suggest you go and take a look at MicroZed Chronicles, specifically issue 138 : http://zedboard.org/content/microzed-chronicles
    Also to note you will need to generate your own PL design/bitsteam (this is covered in article) ,and there are no PL connected LED's on the MicroZed Som (there are on the Zedboard which is used in the example). So you can either subsitiue registers in your PL design or use LEDs if you have the MicroZed Carrier Card.
    --Josh
