Software Application Development Access to the register of PL with Linux
  • Subscribers 363 subscribers
  • Views 241 views
100mokhtar
100mokhtar over 13 years ago
Hi all,
I did this tutorial http://zedboard.org/content/creating-custom-peripheral and everything goes OK(with Run as configuration) . Also, I used the SW regiser:
main()
printf("main
volatile short *r0=   0x67000000;
volatile short *r1=   0x67000004;
volatile short *r2=   0x67000008;
short read_value, read_value_1 ,read_value_2;
//write/////
*r0=   88888;
*r1=   888;
*r2=   90;
///read////
read_value = *r0;
read_value_1 = *r1;
read_value_2 = *r2;
After that I passed to Linux, so I created the new boot.bin file for the SD card.
The problem when I use this program with Linux, an error appear to me:
main
Segmentation fault
Any Help please??
Moktar.
    The Tutorial is for Baremetal programming.
    With Linux using the MMU you have each program in its own virtual memory space.
    To access physical memory you have to either build your own driver or use the mmap() system call.
    See http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/ug873-zynq-ctt.pdf
