Software Application Development Portability of OpenCV on Zynq 7000
  • Subscribers 363 subscribers
  • Views 707 views
100mokhtar
100mokhtar over 12 years ago
Hi all,
I'm working on the implementation of an image processing system on a ZYNQ-7000 SoC, and I would like to use the OpenCV library for the software part of my project.
Where can I find the Opencv Library dedicated to the Zynq architecture(ARM Cortex A9)?
Thank you
Bouain
    If you are using a linux based OS, you can easily download sources and compile them locally, however, you will need to workout some tweaks to implement hardware acceleration in case you need it !
    Check out Xilinx Application Note 1167: "Accelerating OpenCV Application wiht Zynq-7000..."  It contains a sample OpenCV application with FAST detection algorithm.  The SD image it provides contains the open_cv library.
    -Kevin
