Software Application Development Must I link against libc?
  • Subscribers 364 subscribers
  • Views 716 views
henry10210
henry10210 over 11 years ago
Hello, I am working on a bare metal C++ ELF project targeting Zynq CPU1 (the 2nd CPU).  I successfully tested a simple Xilinx standalone application, and then started removing dependence on the standalone BSP, like this:
* I removed the BSP include and library paths from the project.
* I rewrote the startup.s and asm_vectors.s to not depend on any code from BSP.
But g++ linker is apparently still pulling in libc, as you can see below.  I will NOT use any libc functions.  Is there a way to tell g++ not to link against libc at all?  Thank you for your help!
arm-xilinx-eabi-g++ -L"/mnt/work/Dorking/QP/qpcpp/ports/arm/qk/zynq_rproc/Debug" -Wl,-T -Wl,../src/lscript.ld -o "cpu1app.elf"  ./src/bsp.o ./src/main.o ./src/philo.o ./src/table.o   -lqk
/mnt/opt/Xilinx/SDK/2014.4/gnu/arm/lin/bin/../lib/gcc/arm-xilinx-eabi/4.8.3/../../../../arm-xilinx-eabi/lib/libc.a(lib_a-abort.o): In function `abort':
abort.c:(.text+0x10): undefined reference to `_exit'
    Certain low-level functions (like _exit) are required to be present and are part of the C-runtime provided by libc.  You may not be directly calling any of the functions contained in this object library from your application, but the fact that your compilation is complaining that certain functions are not present proves that there is indeed some low-level code that is attempting to access libc APIs.   You can of course write/include your own versions of the required run-time functions, but you may find there are more than you might think.
    Ron
  • henry10210
    0 henry10210 over 11 years ago in reply to e14 Contributor
    Thank you Ron, I am trying to figure out where in my code I am calling out to anything in libc.  Normally, a linker should print what function is calling out the undefined function, but the output you see doesn't.  Makes debugging difficult...
    You can generate a linker map which will give you more information about locations and calling functions, and that may be sufficient.  Under the Build Settings, look for the Miscellaneous settings under the linker entries and add:
    -Wl,-Map=<yourMapFile.txt>
    If that is still not enough, what you might do is to include the necessary libraries to allow the project to link, but build the libraries with debug information included.  Then run the application in the debugger, which will give you the full call tree and let you see exactly where the offending calls are being made from.
    Ron
  • henry10210
    Thank you Ron, I agree with your suggestions.  I found that the linker has to be TOLD not to pull in the standard libs, and I had to resort to the techniques in this article: www.embedded.com/design/mcus-processors-and-socs/4007119/Building-Bare-Metal-ARM-Systems-with-GNU-Part-1--Getting-Started
    ...and thanks for providing the link to that tutorial information.  Looks like it's pretty comprehensive.
    Ron
