Software Application Development Possibility to change BIG_ENDIAN on ZYNQ
  • Subscribers 363 subscribers
  • Views 1574 views
Hey all,
I'm currently building a communication stack and geting a string of uint32 values from some other devices.
(I cannot change this because its a fixed protocol)
These uint32 values will be sent as MSB first.
But the Zynq will interprete a uint32 with LSB first. Therefore I have a byteswap at the moment which makes calculations quite hard.
I don't want to use a software byteswap because the incomming bytes a sometimes uint8, uint16 or uint32, depending on the previous values, Therefore only using a typecst will be easier.
Is there a possibility to change the endines from LITTLE-ENDIAN to BIG-ENDIAN, so all variables will be interpretet with MSB first?
Andy
    I think you are stuck with a software solution here.  You might want to take a look at this link to see if it helps:
    http://xillybus.com/tutorials/zynq-device-tree-5
    Ron
    Sorry, that link is:
    http://xillybus.com/tutorials/device-tree-zynq-5
    Ron
