Software Application Development Access i2c from u-boot and linux
  • Subscribers 365 subscribers
  • Views 2586 views
paul.hein
paul.hein over 8 years ago
Hello i am using a Picozed Board with Petalinux 2016.3.
I followed the PS I2C tutorial and would now want to use this example to access the pmod max44000 i2c device from u-boot and petalinux.
What should i change to make this possible?
so far i get this error under u-boot
U-Boot-PetaLinux> i2c bus
Bus -1: i2c@e0004000
U-Boot-PetaLinux> i2c probe
No I2C bus selected
U-Boot-PetaLinux> i2c bus 0
Invalid bus 0: err=-19
No I2C bus selected
U-Boot-PetaLinux> i2c dev 0
Setting bus to 0
Failure changing bus number (-19)
And under linux an
i2cdetect -r 0
shows me no active i2c devices and even the pmod max44000 pins don't even get an i2c signal.
For linux i need to somehow adjust the device tree. But how?
And how can i fix my u-boot problem???
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Paul,
    By chance would you be interested in using the PL I2C Controller with the MAX44000 Pmod under Petalinux? From my experience the PL I2C Controller tends to be more reliable then the PS I2C Controller. To get started with this my suggestion would be for you to start with the batemetal Tutorial 09 PL I2C Pmod located here http://picozed.org/support/design/13076/106
    --Josh
  • paul.hein
    0 paul.hein over 8 years ago in reply to jafoste4
    This board is just a starting point, before i change unto a custom designed Board using the same Processor. This custom board is using the ps interface. So the PS interface is what i need.
  • zedhed
    0 zedhed over 8 years ago
    Hi Paul,
    In order to maintain maximum flexibility and allow for future firmware updates to your custom board or product, I would strongly recommend to you that you take a look at the AXI I2C interface that Josh suggested above and consider using that instead of the PS I2C controller.  There are many good examples of how to use that hardware interface under Linux.
    If you absolutely are set on using the PS I2C controller in your design, I am not sure if there are Reference Designs available that would help you.  I would suggest you first start with this documentation on the Cadence driver used under Linux to control the PS I2C interface:
    http://www.wiki.xilinx.com/Cadence+I2C+Driver
    Best Regards,
    -Kevin
  • paul.hein
    I somehow got my solution but only partway.
    using the i2c ps interface under u-boot does still deliver the same error.
    Under Linux i got following solution:
    After enabling the the gpio pin 0 which controlls the mux i can probe the i2c bus. either enable it under u-boot and then boot linux or, enable it on linux following this guide: http://www.wiki.xilinx.com/Linux+GPIO+Driver
