Software Application Development Basic: GPIOs in JE1 MIO Pmod block
  • Subscribers 363 subscribers
  • Views 1066 views
tisler
tisler over 8 years ago
Hello. This is a pretty basic question that I've been struggling with. I am trying to communicate with a GPIO pin (ultimately connected to an encoder) from the JE1 MIO Pmod block from a ZedBoard.
From what I've read with tutorials, on the Vivado side, there are no IPs required besides the main Zynq block.
Right now I just want to turn on and off a pin (actuate high to low) in this block (MIO0 - MIO15) so I left the settings in Vivado alone/in the default state and do not have EMIOs enabled (those are only for the PL side, correct?)
(I am following this tutorial: https://forums.xilinx.com/t5/Xcell-Daily-Blog-Archived/Driving-the-Zynq-SoC-s-GPIO-Adam-Taylor-s-MicroZed-Chronicles/ba-p/389611)
For the software in SDK, I am just changing the
#define ledpin [#]
line to be one of the MIO #'s from the block, say 9 for example. However, I haven't been having any luck communicating with any of the pins.
I would appreciate any help if I am setting up the Vivado hardware configuration wrong, or if I am not accessing the JE1 pins correctly. I am completely new to embedded system programming and working with an SoC/FPGA. Thanks!!
  • jafoste4
    0 jafoste4 over 7 years ago
    So long as you enabled the PS GPIO pins that correspond to the JE1 MIO Pmod, your hardware platform should be ok. That blog you are referencing is what I typically send individuals to for reference.
    Why don't you try taking a look at some of the existing example code for using the PS GPIO driver, You can find it around this location of your sdk install.
    C:\Xilinx\SDK\2018.2\data\embeddedsw\XilinxProcessorIPLib\drivers\gpiops_v3_3\examples
    -Josh
