Software Application Development Bare metal write to sd card using adma2
  • Subscribers 363 subscribers
  • Views 613 views
I have successfully read from a sd card using the bootfile example mmc.c file that uses disk_read with adma2 transfer.
Now I want to extend this to write to the sd card but there is no matching disk_write function using adma2 in the example code.
Can anyone supply this code, or know where I can find it?
    I need the same example ... Maybe anybody has experience with SD write?
    I also want to do SD write.... Anyone has solutions?
    I want to write to the SD card. And I'v got a problem to read SD card.  I also use bootfile example mmc.c and other libs from example, but I can't read any from SD. Can anyone post working project for our  board?
    There is diskio.c file in the vivado installation directory where you can find disk_read and disk_write functions.
