Software Application Development Simple LED Tutorial
  • Subscribers 363 subscribers
  • Views 267 views
Simple LED Tutorial
I just started using the Zedboard and have only managed to run the Hello World example using the Xilinx SDK. I have tried following the Zynq CTT tutorial on how to configure GPIOs, but there seems to be an error connecting asynchronous reset pins.
I am looking at programming the LEDs or buttons using the bare-metal method. Is this the right way to go or should I be looking at using Linux applications instead?
Your help is much appreciated.
  • bhfletcher
    0 bhfletcher over 12 years ago
    A bare metal design to toggle LEDs is definitely going to be simpler. Which Xilinx tool version are you using?
    Bryan
    0 e14 Contributor over 12 years ago in reply to bhfletcher
    I am using Vivado 2014.2. Got it working, turns out the reference design in Vivado was wrong. Thanks for the pointer.
