Software Application Development Linux does not detect usb ssd disk
  • Subscribers 363 subscribers
  • Views 572 views
e14 Contributor over 8 years ago
I'm using microzed board with a linux image generated fromYocto.
I've enabled USB support, SCSI Device Support, USB Mass Storage support, on kernel configuration.
The system boots correctly, but when i plug my SSD disk, no trace appears on console, even lsusb command does not return anything.
Do you have any clue to make the SSD device recognized by the kernel ?
The SSD disk is a USB3 disk, 2TB, SAMSUNG , model PT-2T0B.
Thank you for your help.
Nicolas
    0 e14 Contributor over 8 years ago
    Finally the solution has been found.
    It was my hardware platform that was bad configured. The USB reset Pin was not properly configured ( into Vivado ) so the usb controller was not able to release the PHY RESET Pin.
    Nicolas
