Software Application Development Where Can I Get the XEmacPs Example Code?
  • Subscribers 363 subscribers
  • Views 646 views
I'm new to zed, and have worked on the xemacps driver (bare-metal) for a few days. I find it quite hard to build an ethernet transceiver on my own using this driver. Luckily I happened to find out some posts in this forum said there is an example project for this driver. But I can't find it anywhere. Where did you guys get this code?  Any help will be greatly appreciated.
    Once you have exported your design to SDK open the system.mss file ( under your bsp in the Project Explorer pane on the left if it did not open automatically) and click the 'examples' link to the right of the ps7_ethernet_0 under 'Peripheral Drivers'.
    You might also want to take a look at the LWIP code. While it is a little dated (ISE 14.5) there is a port of the XAPP1026 LWIP implementation for the ZedBoard here: http://zedboard.org/design/1521/11
    -Gary
    Thank you so much for your reply. I was working with the xemacps.c, which was quite annoying. I will check this link out, and get back to you if any questions remains.
