Software Application Development MicroZed_7020,how to mount QSPI flash MTD partitions use jffs2 filesystem?
  • Subscribers 363 subscribers
  • Views 693 views
    Refer to  http://www.wiki.xilinx.com/Zynq+QSPI+Driver ,if execute the following command,error log is output.
    command:
>cat /proc/mtd
>flash_eraseall -j /dev/mtd3
>mkdir qspi_flash0
>mount -t jffs2 /dev/mtdblock3 /qspi_flash0
>dd if=/dev/urandom of=./sample.bin bs=1024 count=4096
>cp ./sample.bin /qspi_flash0/
>umount qspi_flash0
  error log:
  zynq> flash_eraseall -j /dev/mtd3
  Erasing 64 Kibyte @ 5e0000 - 100% complete.Cleanmarker written at 5d0000.
  zynq> mkdir qspi_flash0
  zynq> mount -t jffs2 /dev/mtdblock3 /qspi_flash0
  mount: mounting /dev/mtdblock3 on /qspi_flash0 failed: No such file or directory
  zynq> cd /
  jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005d0000: 0x19ff instead
  jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005d0004: 0x000c instead
  jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005d0008: 0xb0b1 instead
  mount: mounting /dev/mtdblock3 on /qspi_flash0 failed: Device or resource busy
  zynq> dd if=/dev/urandom of=./sample.bin bs=1024 count=4096
  4096+0 records in
  4096+0 records out
  4194304 bytes (4.0MB) copied, 2.917369 seconds, 1.4MB/s
  zynq> cp ./sample.bin /qspi_flash0/
  zynq> cd qspi_flash0/
  zynq> ls
  sample.bin
  zynq> cd /
  zynq> umount qspi_flash0
  jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0a28: 0x193b instead
  jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0a2c: 0x1044 instead
What is the cause of the problem, to solve the problem,what should I do?
In other words, how to mount QSPI flash MTD partitions use jffs2 filesystem and modify the contents of the file system.
    I'm no jffs2 expert, so if anyone else wants to chime in, please do.   Did you initialize the JFFS2 file system in QSPI using the mkfs.jffs2 utility?
    Ron
