Software Application Development PS read data from DRAM
  • Subscribers 364 subscribers
  • Views 557 views
martingaraj
martingaraj over 10 years ago
I got PL writting data to DRAM (I am using full AXI master to directly write data to DRAM). So far I was loading data back to PS by Xil_in32, is there some more efficient way to obtain big chunks of data from DRAM ?
Lets say I got array 256x256 of bytes in DRAM, how shall I load them to PS ? Or how do I efficiently access the data ?
EDIT:
ZedBoard, Bare-Metal
  • zedhed
    zedhed over 10 years ago +1 verified
    Hi MartinGaraj, Please correct me if I am wrong but I think when you say DRAM, you mean the DDR3 DRAM that the PS already has access to. Are you just looking for another way to access the data so that…
  • zedhed
    0 zedhed over 10 years ago
    Hi MartinGaraj,
    Are you just looking for another way to access the data so that you don't have to make calls to Xil_in32() when you want to access that memory space?
    If so, let's say your data is located at 0x00200000 in DDR3 memory you should be able to declare a base memory address which points to the memory location of your matrix data:
    #define BIG_MATRIX_BASE_ADDRESS (0x00200000)
    Then declare a pointer to that memory space:
    uint32_t *big_matrix = (uint32_t *) BIG_MATRIX_BASE;
    Then use your pointer to access that memory space as if it were an array so that you can perform array operations on it from the PS:
    for (long index = 0; index < (256*256); index++);
      big_matrix[index] += 1;
    -Kevin
  • martingaraj
    0 martingaraj over 10 years ago in reply to zedhed
    Perfect, exactly what I was looking for.
