Software Application Development 8 switches of GPIO on Zedboard
  • Subscribers 363 subscribers
  • Views 385 views
cascade99
cascade99 over 10 years ago
Hi
I'm using petalinux 2014.4 and used zedboard pre-defined .hdf. GPIO138 ~ 145 should be the pin connected to the switch. I did following on UART:
echo 138 > /sys/class/gpio/export
echo in > /sys/class/gpio/gpio138/direction
Then I tried to read /sys/class/gpio/gpio138/value after I flip the switch(all 8s), but the value seems always 1.
Anybody knows did I configure the connect the pins for 8 switches?
  • bhfletcher
    0 bhfletcher over 10 years ago
    What do you get prior to issuing the echo for
    ls /sys/class/gpio/
    How did you know the offset was 138? The switches themselves will also have an offset based on their GPIO number. Did you account for the fact that the 8 switches are connected through EMIO?
    Bryan
  • cascade99
    0 cascade99 over 10 years ago in reply to bhfletcher
    I figured it out that 8 switches are GPIO117 ~ 124, I flipped the switch, value changed.
