Software Application Development Zynq unexpected restart of main(): Vivado2013.4, SDK2013.4
  • Subscribers 363 subscribers
  • Views 336 views
Iu2019m using Zynq and switched from Vivado 2013.3 to Vivado 2013.4. When I run my program in SDK 2013.4 there is an unexpected restart of main() function when leaving another function. In SDK2013.3 this fault not occurs. On top of main function I checked and printed the content of slcr.REBOOT_STATUS and slcr.RST_REASON registers and got the values:
slcr.REBOOT_STATUS = 2 => SUCCESSFUL_JTAG_SLAVE
slcr.RST_REASON = 0 => no Reset
So it seems to be all ok and no Reset.
Can anyone give an advice how to find the problem and
fix it.
Thanks in advance
Michael
    You might try to  export your project from Vivado 2013.4 to a new SDK workspace, then 'export' your application files from SDK 2013.3 and import them into your new SDK 2014.4 workspace.
    -Gary
    I create the whole Hardware and Software project completely new for vivado 2013.4 and it doesnu2019t work.
    Then I only create the new Hardware with 2013.4 and use SDK export and import option as you suggested and it works.
    I donu2019t know why the other way doesnu2019t work.
    Michael
