Software Application Development Busybox Web Server Petalinux on ZedBoard
  • Subscribers 363 subscribers
  • Views 1334 views
Hi everyone,
I would create a web interface for Petalinux on Zedboard in order to use my applications on the browser of any device.
For Now I have initialized the busybox web server on petalinux and I have made a simple html welcome homepage
I have two questions:
I put my index.html in /srv/www and everything works fine, but, when I restart the zedboard, the folder is empty and I must copy again all files via ssh. How can I add a "non volatile" html project in petalinux?
The next step will be create push buttons that, on click, send bash commands to the petalinux terminal. How can I do that?
Best Regards
  • zedhed
    0 zedhed over 10 years ago
    Hi ngiolet91,
    I recommend following the steps in Xilinx UG981 to create a custom PetaLinux application used only to store and install your HTML files into the rootfs during the petalinux-build phase.
    http://www.xilinx.com/support/documentation/sw_manuals/petalinux2014_2/ug981-petalinux-application-development-debug.pdf
    Why do you need to send bash commands to the terminal when you could print directives directly to the sysfs mechanisms that control GPIOs for the LEDs?
    -Kevin
