Software Application Development Debug code from a lib
  • Subscribers 363 subscribers
  • Views 434 views
I use a RTOS is build in an lib.a file. If i break in my applicantions code, i can step into the code of the library.
Breakpoints i set inside sorces in my Library are ignored though. How can i break inside my Library?
  • bhfletcher
    0 bhfletcher over 13 years ago
    Did you compile your library with optimizations turned off and debug symbols added?
    Bryan
    0 e14 Contributor over 13 years ago in reply to bhfletcher
    I compiled it with -g -O0 (-g2 would not work).
    Only the breakpoints in my Source work. The Breakpoints (blue dots) have an extra blue check left of them. The ones wihout this check do not work.
    i found the reason. Xilinx SDK must know every library, not only the folder.
