Software Application Development How to control LEDs and read switches from Zynq using Simulink?
  • Subscribers 363 subscribers
  • Views 917 views
I am using Matlab R2013b, ISE 14.4 and a Zedboard. I successfully ran the UDP example model (http://fr.mathworks.com/help/supportpkg/xilinxzynq7000ec/examples/communicating-with-xilinx-zynq-hardware-using-udp-protocol.html) and now I want to control the LEDs and read the switches on the board.
Does anyone know how to do it?
Thanks.
    Hello Dani,
    First I would suggest moving to the current Xilinx Vivado tool suite for your work. The ISE tool suite is pretty outdated and you are more likely to find examples and support for the current tools.
    Would this MathWorks example be useful? You would need to target the ZedBoard rather than the ZC702:
    http://www.mathworks.com/help/hdlcoder/examples/getting-started-with-hardware-software-codesign-workflow-for-xilinx-zynq-platform.html??prodcode=HD
    as well as these:
    http://www.mathworks.com/help/supportpkg/xilinxzynq7000ec/examples/getting-started-with-xilinx-zynq-hardware.html
    http://www.mathworks.com/help/supportpkg/xilinxzynq7000ec/examples/communicating-with-the-fpga-ip-core-on-the-xilinx-zynq-7000-platform-using-axi4-lite-protocol.html
    -Gary
    Hello Gary,
    Vivado tools are not supported by Matlab 2013b. That is the reason why I have to use ISE 14.4.
    Thanks for your help, the first example helped me getting this working!
    Best regards,
    Dani
