Software Application Development Unrecognized Machine ID when booting Linux on Zedboard
  • Subscribers 363 subscribers
  • Views 420 views
After following the tutorial "Ubuntu on Zync-7000 SoC" and booting Linux on Zedboard I get the following error:
reading zImage
3002960 bytes read
reading devicetree.dtb
8451 bytes read
## Starting application at 0x00008000 ...
Error: unrecognized/unsupported machine ID (r1 = 0x1fb71dd0).
Available machine support:
ID (hex)        NAME
ffffffff        ARM-Versatile Express
000008e0        ARM-Versatile Express
00000d32        Xilinx Zynq Platform
Please check your kernel config and/or bootloader.
What is the problem here and how can I fix it?
    jyotsna,
    You're not the first one to run into this problem.
    Apparently, u-boot passes a machine ID to the kernel when u-boot tries to load it, and there is a mismatch somewhere. A similar problem happened here: http://www.zedboard.org/content/u-boot-machine-id
    Did you compile everything from its source, or use the pre-compiled versions? If you compiled it from scratch, you might need to mess with the device tree (.dts) and add a few strings into the compatible section (as described in the link).
    Good luck!
