Software Application Development Partial reconfigutration from SDK tutorial
  • Subscribers 364 subscribers
  • Views 463 views
Is there a tutorial for start ahead with partial reconfiguration from SDK C code . I have already done the partial reconfiguration by IMpact but I need to do the partial reconfiguration from the running code dynamically. I need information where to put my bit streams and how to read it and at last to partial reconfigure using Pcap
thank you
  • zedhed
    0 zedhed over 11 years ago
    Hi MRihani,
    There is a Xilinx application note that shows how to do partial reconfiguration on their ZC702 board.  The flow should be nearly identical for a ZedBoard, MicroZed, or other Zynq target.
    http://www.wiki.xilinx.com/XAPP1231+-+Partial+Reconfiguration+of+a+Hardware+Accelerator+with+Vivado+Design+Suite
    -Kevin
    0 e14 Contributor over 11 years ago in reply to zedhed
    thanks for the url
    I build my application but while i was trying to read from sd card the bit streams I have error :
    dma transfer no  complete so  the application could not open the bitstreams
    dma_trans_cmpl: Error: (0x00018000)
    what should i do now .
    The error is due not disabling Dcache so you should before transferring bit streams to DDR you should disable DCache:
    tXil_DCacheDisable();
    Hope it help someome.
