Software Application Development HelloWorld in QSPI
  • Subscribers 363 subscribers
  • Views 285 views
HelloWorld in QSPI
I just started with the MicroZed.  My first application is the HelloWorld app, and it works just fine with the JTAG, running as debug.
I built a BIF with the FSBL (release) and HelloWorld (release).  I burned the image to flash.  The UART has no output when running from flash.
I modified the FSBL so I could debug booting from QSPI and it seems to do the right thing and loads and attempts to run HelloWorld, but still no output from the UART.
Any suggestions?
    Update to previous comment.
    If I run the FSBL (release) using the JTAG, the HelloWorld app is loaded from the QSPI and runs fine.
    Why does the FSBL not run from QSPI?
    If I connect to running target, both cores are looping on WFE.
    You need to set the FSBL partition type to bootloader in the BIF.
