Software Application Development TTC Interrupt
  • Subscribers 364 subscribers
  • Views 696 views
TTC Interrupt
zanabonir
zanabonir over 10 years ago
Dear Forum
I'm plaing with Timer0 of module TTC0, and all seems ok...I use it in overflow mode, set prescale and I can see the Counter Register Value moving.
Now I want manage a INT,so I set the IER (offset 60h),and set the -int on overflow- (bit 10h).
But I cant understand how to setup a callback function  (Adam Taylor stop at this point)
So question is what is the logical sequence...or better, if there is a detailed document about INT managment.
Thanks in advance
Roberto
  • jafoste4
    0 jafoste4 over 10 years ago
    Hello Robiberto,
    I was just about to suggest you look through the Adam Taylors blog then I noticed you had already gone through it base off of your above post. It is an excellent resource! Now to point you to some other resources that should help you with your interrupt question.
    https://www.xilinx.com/support/documentation/xcell_articles/how-to-use-interrupts-on-zynqsoc.pdf
    https://forums.xilinx.com/t5/Xcell-Daily-Blog/Interrupts-on-the-Zynq-SoC/ba-p/445376
    https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug1165-zynq-embedded-design-tutorial.pdf
    --Josh
  • zanabonir
    0 zanabonir over 10 years ago in reply to jafoste4
    Thanks for reply..
    yes the link you send me was sufficient for solve the problem.
    Many thanks
    Roberto
