Software Application Development Help me ~! I can't use usb otg in zedboard.
  • Subscribers 364 subscribers
  • Views 511 views
ywkim
ywkim over 9 years ago
hi everyone~!
i use
Petalinux 2013.10 + vivado 2013.4 + analogdevices-kernel + zedboard
so i  get a result HDMI Display. it is work very well.
but, i can't use usb-otg port.
I implemented it by referring to the following site.
https://2015_fall_nctu_esd.hackpad.com/ep/pad/static/2ApxmX0YBiH
One of the above site contents is different.
git checkout 2014_R1.
and i check all of it and devicetree(system.dts) following site.
http://www.wiki.xilinx.com/Zynq+Linux+USB+Device+Driver
i can not fine follworing message in petalinux booting (dmesg).
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
and when i connect mouse to usb-otg, the mouse is not work(no power).
but if i use other kernel, the mouse is work very well.
why this happen... ? i don't know.
please let me know~!!
Thank.
Best regards.
note:
i found one thing.
The analog device kernel does not have a "driver / usb / otg" folder. Is it related to this?
  • narrucmot
    0 narrucmot over 9 years ago
    You mention you are using PetaLinux 2013.10 and Vivado 2013.4?  To validate the USB OTG is working I would duggest downloading and installing the PetaLinux 2013.10 ZedBoard BSP from the Xilinx archive:
    (https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools/archive.html
    Once the BSP is installed you can examine the devicetree and compare to your current settings.
  • ywkim
    0 ywkim over 9 years ago in reply to narrucmot
    oh~ Thank you so much~!!
    i will try to do so...!!
