Software Application Development Initializing EmacPs and ScuGic
  • Subscribers 363 subscribers
  • Views 690 views
I am trying to read all incoming Ethernet packets into a linked list in main memory.
I am having the hardest time initializing the Ethernet driver EmacPs. I believe that I have gotten the ScuGic working. I have been trying to dissimilate the Xilinxs Peripherals Test Example code, but I haven't had much luck.
Is there a guide I can follow with simple examples or something?
Any help would be... Well, really helpful.
Thank you.
    It might be of note, I got the Xilinxs Peripherals Test Example from the Vivado 2014.3. It was an option when starting a new project.
    One of the application templates included with the SDK is for a simple Echo Server application.  You should be able to generate that for any valid hardware design that includes the Ethernet interface, and test it using a telnet/ssh client on your host.   You can use the working design as a starting point to add your own custom code.
    Ron
    Thank you so much! This will be incredibly helpful!
