Software Application Development Read Data From SD-CARD
  • Replies 8 replies
  • Subscribers 367 subscribers
  • Views 1561 views
hello
I am new to SDK environment , and i am working on zedboard(Z7020).
i want to read data from SD-CARD and display it on tera term using SDK.
Can someone help me in this part.
thanks in advance.
prakhar
  • zedhed
    0 zedhed over 10 years ago
    Hi prakhar,
    You are going to get the best results with the SD access by using some sort of OS or even U-Boot.
    If you just want to try it out to see it work, there is a xilffs_polled_example.c file in the following directory which might work for what you want:
    C:XilinxSDK2015.4dataembeddedswlibsw_servicesxilffs_v3_1examples
    If you intend to move toward writing the SD card, please check out these other threads ahead of time and understand the issues related to writing:
    http://zedboard.org/content/sd-card-example-design-using-standalone
    http://zedboard.org/content/standalone-sd-card-sdio
    -Kevin
    0 e14 Contributor over 10 years ago in reply to zedhed
    Hi Kevin
    thanks for your reply .
    I have tried that example
    and every time i do so i get error as FR_NOT_READY.
    this error corresponds to
    "The storage device cannot work due to a failure of disk_initialize function due to no medium or any other reason."
    i have tried this example with 2 different SD CARDS and i am getting the same results.
    Please help me with this issue .
    Thanks in advance
    Prakhar
    Well !
    the example code xilffs_polled_example.c passed successfully.
    but it is passed successfully on Delkin SD-CARD but when i am using Sandisk micro SD CARD with Samsung SD card adapter for micro SD its giving error .
    Can anyone explain why that is happening ??
    Hello
    Now i am able to read data from SD-CARD but i am able to read the ASCII values of data , instead i want to read pixel value of image.
    any help in this case ??
    thanks in advance
    -Prakhar
  • the00772000
    0 the00772000 over 9 years ago in reply to e14 Contributor
    Hello
    I want to ask you how to solve the error: "FR_NOT_READY"??
    I try Xilinx\SDK\2016.1\data\embeddedsw\lib\sw_services\xilffs_v3_2\examples\xilffs_polled_example.c, too, and get the same error.
    Thanks  in advance.
  • jafoste4
    0 jafoste4 over 9 years ago in reply to the00772000
    Here is a good place to start looking.
    https://forums.xilinx.com/t5/forums/searchpage/tab/message?q=FR_NOT_READY
    --Josh
  • the00772000
    0 the00772000 over 9 years ago in reply to jafoste4
    Hi
    I have visited this place, but it seems useless.
    When SDK run to the code "XSdPs_SdCardInitialize", it just stop, and console appears nothings.
    When SDK run to the code"disk_initialize", return 3.
    https://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/p/462176/1660114
    This article propose that
    " When the FatFs functions call disk_initialize() and receive a return value of STA_NOINIT, those functions will in turn return FR_NOT_READY to their calling functions."
    Do you have any idea?
    Thanks for your reply.
  • salma_shalaby
    0 salma_shalaby over 9 years ago in reply to e14 Contributor
    Hi
    Did you manage to read images from the SD card? If so, please help.
    Salma
