Software Application Development kbhit() function for bare metal
  • Subscribers 364 subscribers
  • Views 928 views
chipslinger
chipslinger over 13 years ago
I am looking for a kbhit() function. I'm starting from the helloworld application, using a UART. Can anyone let me know where this is located?
(There doesn't seem to be a conio.h include file anywhere).
If not, which file contains the software uart routines? Perhaps I can add a kbhit() into this file.
fyi: kbhit() is a non-blocking version of getchar() that returns 1 when a key is hit. It allows you to see if a character has been hit without waiting for it (e.g. for "escaping" out of a loop).
Thanks.
  • zedhed
    0 zedhed over 13 years ago
    Hi chipslinger,
    For the LX9 MicroBoard, which used MicroBlaze, we wrote our own line handler function.  Keep in mind, that hardware design used a UARTLite device instead of the PS UART so there is a call to XUartLite_Recv() to get the contents of the UART receive buffer which was non-blocking.  In looking through the Zynq Standalone BSP, it looks like there is a similar function for the PS UART code file xuartps.c named XUartPs_Recv() which is also non-blocking.
    int my_get_line_poll(char * line, int maxlen)
        int buffer_index;
        char character_copy = 0;
        u8 DataBuffer[MAX_LINE_LENGTH];
        unsigned int received_char_count = 0;
        static unsigned int total_received_char_count = 0;
        // Make a call to UartLite instance to check for new characters
        // coming in.
        received_char_count = XUartLite_Recv(&UartLite, DataBuffer, (MAX_LINE_LENGTH - received_char_count));
        // Check to see if there were any characters received, otherwise return.
        if (received_char_count > 0)
            for (buffer_index = 0; buffer_index < received_char_count; buffer_index++)
                // Make sure that the line length has not been reached.
                if (total_received_char_count == MAX_LINE_LENGTH)
                    // Force a line feed character, this is the end of the
                    // line that is being polled for.
                    outbyte('r');
                    outbyte('
                    // Null terminate the string so that it is still a
                    // valid string.
                    line[total_received_char_count] = 0;
                    // Reset the total character count in preparation for the
                    // next line yet to be received.
                    // Return the total count of characters in the current line.
                    return MAX_LINE_LENGTH;
                // Get the next character that was received from the Uart Lite
                // device.
                character_copy = (char) DataBuffer[buffer_index];
                // Determine what action to take with the next received
                // character.
                if (character_copy == '
                    // Ignore it.
                else if (character_copy == 'r')
                    // A line feed character has been encountered, this is the
                    // end of the line that is being polled for.
                    outbyte('r');
                    outbyte('
                    // valid string.
                    // Determine the number of characters that are in the line.
                    received_char_count = total_received_char_count;
                    return received_char_count;
                // Check for backspace or delete key.
                else if ((character_copy == 'b') || (character_copy == 0x7F))
                    if (total_received_char_count > 0)
                        outbyte('b'); // Write backspace
                        outbyte(' ');  // Write space
                        total_received_char_count--;
                // Check for escape key or control-U.
                else if ((character_copy == 0x1b) || (character_copy == 0x15))
                    while (total_received_char_count > 0)
                else
                    // Echo character back to the user.
                    outbyte(character_copy);
                    line[total_received_char_count] = character_copy;
                    total_received_char_count++;
        return -1;
    YIKES! Sorry about the way this forum mangles this C code, hopefully it is still somewhat readable on the other end.
    The intent of this function was to poll until a complete line with carriage return character was entered.  However, maybe doing something similar but limited to a single character would help you with what you need?
    -Kevin
  • chipslinger
    0 chipslinger over 13 years ago
    Yes, I think this function would work. Unfortunately, I haven't had any luck figuring out at what level in the code the structures/variables that this routine requires are maintained. I've grepped the code tree for the routines in this source file, but nothing comes up.
    Any ideas?
  • zedhed
    Hi chipslinger,
    Which routine are we talking about here XUartLite_Recv() or XUartPs_Recv()?
    If you are looking into using XUartPs_Recv(), I see the source code listed in project_14_2project_14_2.sdkSDKSDK_Exportstandalone_bsp_0ps7_cortexa9_0libsrcuartps_v1_01_asrcxuartps.c as I am using a 14.2 standalone example project.
    Looks like that function is going to need the XUartPS struct which is in the xuartps.h file:
    * The XUartPs driver instance data structure. A pointer to an instance data
    * structure is passed around by functions to refer to a specific driver
    * instance.
    typedef struct {
    tXUartPs_Config Config;t/* Configuration data structure */
    tu32 InputClockHz;t/* Input clock frequency */
    tu32 IsReady;tt/* Device is initialized and ready */
    tu32 BaudRate;tt/* Current baud rate */
    tXUartPsBuffer SendBuffer;
    tXUartPsBuffer ReceiveBuffer;
    tXUartPs_Handler Handler;
    tvoid *CallBackRef;t/* Callback reference for event handler */
    } XUartPs;
    -Kevin
  • chipslinger
    I have a more basic problem.... Using the default Hello world program, getchar() doesn't work !!!
    I checked to make sure the txd/rxd pins are connected in the assignment chart, and I looked on the USB-Serial converter. When I hit a character, it isn't recognized...
