Software Application Development u-boot undefined instruction error
  • Subscribers 363 subscribers
  • Views 495 views
When I try to run u-boot.elf from xmd after building it from source it starts to run but then crashes with an undefined instruction:
Output from the terminal.
U-Boot 2013.04 (Jul 13 2013 - 17:45:21)
Memory: ECC disabled
DRAM:  512 MiB
WARNING: Caches not enabled
MMC:   zynq_sdhci: 0
SF: Detected S25FL256S_64K with page size 64 KiB, total 32 MiB
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   Gem.e000b000
Hit any key to stop autoboot:  3 undefined instruction
pc : [<1ffa246c>]          lr : [<1ffa2404>]
sp : 1fb55ed8  ip : 0029cbc1     fp : 04000020
r10: 040405ec  r9 : 1bf76000     r8 : 1fb55f40
r7 : 000000c0  r6 : 1fb57f18     r5 : 00002710  r4 : 00002710
r3 : 00000000  r2 : 000f4240     r1 : 00000003  r0 : a6f97c30
Flags: nzCv  IRQs off  FIQs on  Mode SVC_32
Resetting CPU ...
00  r2 : 000f4240     r1 : 00000024  r0 : 85bed9e0
Flags: nzCv  IRQs on  FIQs on  Mode SVC_32
Resetting CPU ...
Steps :
I downloaded the u-boot code by
>git clone git://github.com/Xilinx/linux-xlnx.git
>make zynq_zed_config
>make
It compiles fine and generates u-boot elf file.
Then from xmd:
>connect arm hw
>rst
>source ps7_init.tcl
>ps7_init
>init_user
>dow u-boot.elf
>con
Thanks in advance...
    I've exactly the same problem with the xilinx-v14.6.02 version of u-boot (but it work correctly with the xilinx-v14.4 version).
    Could you find a solution?
