Software Application Development Split boot: U-Boot in QSPI, Linux in SD
  • Subscribers 363 subscribers
  • Views 365 views
I'm prototyping a system using the MicroZed board. The intended target board has QSPI Flash that is expected to be mostly consumed by the FSBL, PL bitstream, and U-Boot, so the Linux boot files need to be in eMMC flash.  The eMMC flash will also be soldered to the target board, so no opportunity to load the Linux files other than through U-Boot.  My MicroZed prototype boots Linux from the SD, but if I load U-Boot from QSPI, then load/boot the same Linux files from the SD image, the boot hangs partway through. Any ideas?  Thanks.
    Our PicoZed SOM has eMMC flash onboard and we have an application note that describes how to use the QSPI and eMMC memories to boot PetaLinux in a similar fashion to what you describe. Take a look at the "Application Note on Booting PicoZed Using QSPI and eMMC" and see if it answers your questions. You can download the app note here:
    http://zedboard.org/support/design/4701/76
    -Gary
