Software Application Development Linaro Software Resetting Programmable Logic alone
  • Subscribers 363 subscribers
  • Views 385 views
I am trying to software reset the whole programmable logic(which uses FCLK_RESET0_N) from Linaro.I found that we can do it through the SLCR(System Level control Registers) and found slcr.c Platform driver(in linux-xlnx/arch/arm/mach-zynq) which has xslcr_reset_periph()  function to reset a peripheral.....How do I use this driver to perform a reset? Do I need to write a character device driver that communicates to the platform driver for this?  Can anybody please give me any reference material for doing this as I am new to Linux device drivers ?..Thanks!
  • zedhed
    0 zedhed over 13 years ago
    Hi ckbwaj,
    What is your end goal for resetting the PL?  Is it to save power?  Is it to clear your configuration?  Or you are you ultimately looking to re-configure the PL?
    If your end goal is to re-configure the PL, I suggest taking a look at XAPP1159:
    http://www.xilinx.com/support/documentation/application_notes/xapp1159-partial-reconfig-hw-accelerator-zynq-7000.pdf
    This shows an example of how to write a partial reconfiguration bitstream to the /dev/xdevcfg device to reconfigure a specific partition in the Zynq PL fabric.
    -Kevin
