Software Application Development Need Microzed BSP 2015.4 for Petalinux
  • Replies 7 replies
  • Subscribers 364 subscribers
  • Views 782 views
I'm getting started with Petalinux.
I've installed Petalinux 2015.4 following the User Guide. The User Guide says I need to install the BSP for Petalinux 2015.4.
However, I can't seem to find it anywhere. Although I do see several other people looking for it.
Where can I download the Microzed BSP for Petalinux 2015.4?
Cheers,
David
    I've done many Google searches, but I'm only able to find other folks with the same request.
    Do you know of a BSP for Microzed that I can use with Petalinux 2015.4?
    Thanks!
    David
  • drozwood90
    0 drozwood90 over 10 years ago
    Hi there,
    This is being worked on.  Expect to see it listed under the reference designs once it is completed.
    http://microzed.org/support/design/1519/10
    --Dan
    Hello David,
    We originally held off generating a PetaLinux 2015.4 BSP hoping that the USB OTG issue in PetaLinux 2015.4 would be resolved first. That has not happened so we will should be posting one soon.
    -Gary
    Thanks for the update!
    David
    Hey Gary,
    I'm reading up on how to build a BSP for Petalinux and it doesn't seem too scary. I saw this in another post:
    6. You many need to augment the subsystem/linux/configs/device-tree/system-top.dts file to get Ethernet and QSPI working correctly.  You can generally copy the system-top.dts file from the previous (2014.4) version of the BSP for that board.  But for the very first build, you can skip this step just to get your system booted and see what is working.
    So, do you think if I snagged the dts file contents for the previous version I would be on the path to success?
    Is the system-top.dts file from the most recent MIcrozed BSP something that I would have access to?
    You know, give a man a fish vs. teach a man to fish and all that.
    Cheers,
    David
  • zedhed
    0 zedhed over 10 years ago
    Hi David,
    You are right, building the BSP is not hard but there are a lot of small details that you can get tripped up on.
    As a starting point, you can look at what we did for automating the 2015.2 BSP builds by looking at this script on our Github:
    https://github.com/Avnet/software/blob/master/petalinux/scripts/make_mz_petalinux_bsp.sh
    That is the same script that we will base the 2015.4 BSP automation work on also.
    As for the system-top.dts file, you can see what was used for 2015.2 here:
    https://github.com/Avnet/software/blob/master/petalinux/configs/device-tree/system-top.dts
    -Kevin
  • zedhed
    Hi David,
    I am sorry for the delay in getting these posted.  The USB host problem we saw earlier has been resolved.
    The 2015.4 PetaLinux BSPs for MicroZed SOMs are now posted here:
    -Kevin
