Software Application Development Using PS_DMA in linux
  • Subscribers 363 subscribers
  • Views 592 views
Hi, I succeeded to use PS_DMA driver to transfer data in standalone system.
Next step, I tried to use linux from sd card. The SD card which was enclosed with zedboard kit has linux image, so I made 'Boot.bin' file and tried to test led. It works well.
Now, I want to use DMA(PS_DMA) in linux, but I don't know how to use this driver in linux.
Please, tell me how to use PS_DMA driver in linux.
Thanks!
    I'm new in Linux, does anyone know a way how to use PS_DMA driver in linux? For example the PL330 driver I found on this page:
    http://www.wiki.xilinx.com/Linux+Drivers
    Thanks in advance
    I think I have to generate a .ko-file and load it into kernel with insmod. Right?
    I tried different Makefiles from different sources to generate a .ko-file, but no one works.
    Can anyone give me evidence how to write a working Makefile to generate a .ko-file from .c-file.
    Thanks in advance
    I finished the tutorial on  http://www.wiki.xilinx.com/Zynq+Linux+pl330+DMA
    When I use the DMA Controller I get the error message:
           dma buffer alloc - d @0x1fb22000 v @0xffdfa000
           xfifo_dma 78000000.fifo_dma: DMA fault type 131072 at address 0x1f89f021 on channel 1
    On second try I get nearly the same error Message but with different addresses:
           dma buffer alloc - d @0x3810000 v @0xffdfa000
           xfifo_dma 78000000.fifo_dma: DMA fault type 131072 at address 0x3811020 on channel 1
    Can anyone give me an advice how to fix this problem?
