Software Application Development the pre-built image is not working
  • Subscribers 363 subscribers
  • Views 887 views
at the bottom of the websites
"http://wiki.xilinx.com/zynq-release-14-1
http://wiki.xilinx.com/zynq-release-14-2"
the pre-built image provided is not working.
i downloaded it and copied them to the SD card.but linux was not booted up successfully.
did anyone else have tried it?
    jameschennerd,
    As Jason mentioned, that is the incorrect image to use - it is for the Xilinx Zynq development board (the ZC702).  Please reference this link for the Out-Of-The-Box image for the Zedboard.
    http://zedboard.org/node/241
    Hope that helps.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Is there a way to port 14.3 or 14.2 for zedboard?
    Or do we have to compile only the kernel and replace only that?
    You can get the SD-Card image that ships from Digilent here:
    http://www.zedboard.org/node/241
    Or you can recompile the kernel your self if you feel you need additional functionality.
    I'll see what I can dig up on a 14.3 port for the Zedboard.
