Software Application Development Motor(Servo) and Zedboard
  • Subscribers 363 subscribers
  • Views 354 views
I have a simple code to send PWM to a servo. servo is connected to external 5v and gnd. The control pin is connected to JA1 but there seems to be no response when i test the code. Do i need other peripherals to connect the servo? and which pin is best for external device on the zedboard?
thanks
    You have a 5v system, and the logic levels on pin JA1 are not 5 volts!
    Think about it:  to interface logic to anything, the voltage levels 9standards) must match (or at least inter-operate correctly).
    You will need a level-shifter device to convert the zedboard voltage levels to the 5v levels your logic requires....
