Software Application Development OLED Zedboard
  • Replies 7 replies
  • Subscribers 363 subscribers
  • Views 853 views
OLED Zedboard
I want to know how to turn on the display "OLED" the Zedboard, from the SDK editor, I work on PlanAhead "Windows7".
Thank you.
    thank you, but this post discusses the use of OLED using linux, and I have windows7, and I work with the PlanAhead software.
    http://zedboard.org/node/511
    hello,
    thank you for the link, I actually do not know because I work on ISE PlanAhead working on. and I program in verilog, but thank you for the help.
    I do not know how to work with ISE, because I work on PlanAhead. and I program in verilog, but thank you for the help.
    ISE is a collection of applications that include PlanAhead and ProjectManager. PlanAhead can import an .xise project. Also, PlanAhead supports mixed mode so you can use both VHDL and Verilog in the same project.
    BTW, have you bothered to Google for the answer? Just search for "OLED Verilog"
    I also suggest you learn VHDL as well.
    If you mentioned first that you code in Verilog you would not have wasted 2 people's time. The fact that you use Windows 7 is irrelevant. Also SDK and Planahead are two different things.
    Next time, first do a Google search and if you are still stuck say this:
    "I am looking for Verilog code to allow me to use the OLED display on the Zedboard"
    Yes you're right. I asked a PlanAhead project that I do not know how to use the ISE software. Can you please do show me a document that explains how I want to use VHDL and VERILOG code in the same PlanAhead project?
    Thank you.
