Software Application Development Make memory region uncacheable
  • Subscribers 364 subscribers
  • Views 1239 views
how can one make a memory region uncacheable?
For example in the Ethernet Driver description stands:
It is expected that all BDs are allocated in from uncached area.
In an example program they do the following:
* The BDs need to be allocated in uncached memory. Hence the 1 MB
* address range that starts at address 0xFF00000 is made uncached.
Xil_SetTlbAttributes(RX_BD_LIST_START_ADDRESS, 0xc02);
But firstly I did not find out how to propperly use this function to set the appropriate attributes and secondly I do not understand why one should set TLB attributes, if one does not even use virtual memory.
Can somebody help?
P.S. I posted the same question to http://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Make-memory-region-uncacheable/td-p/530583 but nobody replied
    The answer is here:
    http://www.silica.com/fileadmin/02_Products/Productdetails/Xilinx/Zynq_MMU_caches_control_ver1.0.pdf
    0 e14 Contributor over 9 years ago
    Sir,
    Please send me ethernet working example code.
    If you have any documentation with that it would be helpful.
    Please send it mail id
    ashokavanjare@gmail.com
  • svsch14
    0 svsch14 over 9 years ago in reply to e14 Contributor
    hi sir, this is srinivas,
    i need ethernet example code for transmitting data from zynq 7000 soc board to host PC.
    please send me if u have.
    iam using zynq(zc7z035) and phy( marvell 88e1512)
