Software Application Development Using ECC
  • Subscribers 364 subscribers
  • Views 596 views
Using ECC
I would like to know how to use the ECC.
First, I tried to add writel() code to the ddrc.c file. but booting is stop at writel() function.
And then, I modified memory according to the Zynq-7000 All Programmable SoC Technical Reference Manual. but board was not booted with red led (D17, D18).
How can I use the ECC?
  • jafoste4
    0 jafoste4 over 10 years ago
    Hello Hyeonsu.kim
    What board are you trying to target? What operating system are you using? What tool set are you using, Vivado or SDK and what version?
    I also found a few articles that you may find useful.
    https://forums.xilinx.com/t5/7-Series-FPGAs/Zynq-DDR-with-ECC/td-p/676930
    http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+-+32+Bit+DDR+Access+with+ECC+Tech+Tip
    --Josh
    Thanks Josh,
    I already saw that article. But it was not useful for me.
    I want to use the ECC without using FPGA.
    Do you have any ideas?
    here my target and tool
    target board
     - 7015 SOM
     - FMC Carrier Card
    tool
     - petalinux2015.2.1 (SDK)
    0 e14 Contributor over 10 years ago in reply to jafoste4
    Thanks Josh,
    target board
     - 7015 SOM
     - FMC Carrier Card
    tool
  • jafoste4
    Hello Hyeonsu.kim,
    Unfortunatly we do not have much experience with ECC not using the PL. I did find this forum post that you may find useful over at Xilinx.
    https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/ZYNQ-PS-DDR-ECC-Recomendation-and-EMI-effects/m-p/471280/highlight/true#M2485
    I would also suggest you post your question over there to capture a broader audience.
    --Josh
