Software Application Development Vitis Unified IDE gets stuck when selecting OS and processor
  • Replies 8 replies
  • Subscribers 362 subscribers
  • Views 5909 views
quadzilla
quadzilla over 2 years ago
I'm trying to learn how to use the Vitus Unified IDE2023.2, but the online documentation and tutorials seem a bit sparse.
I tried to create a new platform component within an empty workspace.  After I select an XSA file though, Vitis gets stuck at the step shown below. The software doesn't hang but it just keeps spinning at this point.
Some postings that I found online suggest that I need to install a device tree generator. Is this so?   Our team is using Windows and the instructions that I found were all for Linux, so I don't know what to make of that.
  • CJK15
    CJK15 over 2 years ago in reply to quadzilla +1
    Go to the Xilinx link and find Vivado Lab Solutions - 2023.2. Download the appropriate file for your system (windows). This should work, it worked for me. If downloading the lab solution does not work…
  • CJK15
    You are missing a download file. Go back to the Xilinx where you downloaded the software, and make sure you have all files downloaded not just the Vitis installer. I had this same issue and this worked for me.
  • quadzilla
    quadzilla over 2 years ago in reply to CJK15
    I executed the AMD Unified Installer for FPGAs & Adaptive SoCs 2023.2: Windows Self Extracting Web Installer and selected all the options below.  None of the remaining options seem relevant.  Were you referring to some other installation file?
  • javagoza
    javagoza over 2 years ago
    Are you sure that the .xsa was created with the same version of Vivado, 2023.2?
  • quadzilla
    quadzilla over 2 years ago in reply to javagoza
    Absolutely. It's the only version that I have.
  • CJK15
    Go to the Xilinx link and find Vivado Lab Solutions - 2023.2. Download the appropriate file for your system (windows). This should work, it worked for me. If downloading the lab solution does not work try downloading Vivado ML Edition Updates 1 & 2 as well.
  • fouad_jh
    fouad_jh over 2 years ago
    Try to use XSA file from available sample project similar to your board. Just to make sure your tools installation is fine. I haven't really used Vivado\Vitis on Windows. Try to install the tools on another PC. I usually download the offline installer which is about 100GB just to avoid issues with connection while installing. If things don't work out, you might want to try Linux on a VM?
  • quadzilla
    quadzilla over 2 years ago in reply to fouad_jh
    The XSA and the new project are both for a MicroZed board, so it's definitely not a board incompatibiilty issue.
  • javagoza
    javagoza over 2 years ago in reply to quadzilla
