Software Application Development Mysterious syntax error with "set" command in TCL script
  • Replies 9 replies
  • Subscribers 361 subscribers
  • Views 1860 views
quadzilla
quadzilla over 2 years ago
Another Linux vs Windows issue. We have a TCL script that works under Linux when we use "vitis -s <scriptname>", but it gives us problems at the following line under Windows.  Any idea what's going wrong here?
    Jan Cumps over 2 years ago +1
    /temp/workspace is most likely not a windows root directory.
  • quadzilla
    quadzilla over 2 years ago +1
    Found the problem. A co-worker let me astray when he said we should use "vitis -s". I had to dig deeper to learn that this is only for Python scripts. In othe words, it was a documentation error on his…
  • dyessgg
    dyessgg over 2 years ago
    I'm assuming you're moving the file between the platforms in a way that converts the line endings.
    It would be helpful to see a few lines above and below the offending line.
    Maybe try turning on your editor's option to visualize "white space" characters.  There might be something lurking there Windows doesn't like.
  • quadzilla
    quadzilla over 2 years ago in reply to Jan Cumps
    No, c:/temp/workspace definitely exists.
  • quadzilla
    quadzilla over 2 years ago in reply to dyessgg
    Since you asked, this is what Notepad++ shows me.  I don't see anything unusual there.
    shabaz over 2 years ago in reply to quadzilla
    Are there any TCL commands above the snippet you supplied? Maybe the TCL interpreter isn't invoked and Windows is executing it as a different script, throwing the error. You could test with other TCL commands. It's been a decade since I last used TCL so I cannot remember a single TCL command any more : (
  • quadzilla
    quadzilla over 2 years ago in reply to shabaz
    Nope. Those are the very first lines.
    Could Vitis not be invoking the TCL interpreter?  I suppose so, but I wouldn't know how this could happen or why.
    Jan Cumps over 2 years ago in reply to quadzilla
    yes but that's not /temp/workspace
  • quadzilla
    Found the problem.  A co-worker let me astray when he said we should use "vitis -s".  I had to dig deeper to learn that this is only for Python scripts.  In othe words, it was a documentation error on his part. Sorry for the confusion, and thanks everyone.
  • padudle
    padudle over 2 years ago
    I think you should make that a relative pathname like ./temp/workspace/system_build.xsa for better portability.
    Sometimes putting the path in {} brackets helps. I think it tells Xilinx TCL to convert to the native path format of the local machine.
