Software Application Development Simple Python Question
  • Subscribers 364 subscribers
  • Views 780 views
ysivelip
ysivelip over 7 years ago
I'm new to Linux, Python and the Anjuta IDE. I have created a new file called hello.py. This is the contents of that file: Code:     #!/usr/bin/env python     print "Hello World!" All I want to do is run this in the terminal. I go to Run > Execute but I get the following error message: Program 'home/joe/Programming/Python//hello.py' does not have execution permission How do I get this really simple program to run? Thanks
  • gecoz
    gecoz over 7 years ago
    Hi Carlos,
    Looks like your IDE is trying to run your code as a script, which means it is trying to launch the file as an executable. In Linux, files have got permissions associated with them, i.e. files can be readable, writeable and/or executable. For a file to be able to be executed as script, the file itself needs to have executable permission, and this is probably what is missing in your set up (newly created files usually only get read/write permissions).
    To fix that, you need to make your file executable, by giving it executable permission. This can be done using the chmod command, like this:
    chmod u+x home/joe/Programming/Python/hello.py
    Once run the above command, try "Run>Execute" again in your IDE, and it should work.
    Fabio
  • ysivelip
    Thanks Fabio
    "I'm new to Linux, Python and the Anjuta IDE. I have created a new file called hello.py. This is the contents of that file: Code:     #!/usr/bin/env python     print "Hello World!" All I want to do is run this in the terminal. I go to Run > Execute but I get the following error message: Program 'home/joe/Programming/Python//hello.py' does not have execution permission How do I get this really simple program to run?"
    Any other advice??
    IT rate
