Software Application Development Ultrazed (Petalinux 2018.2) does not boot with UART lite device as primary stdin/stdout console
  • Subscribers 363 subscribers
  • Views 2438 views
  • ultrazed
  • petalinux
  • uart
gatsuk86
gatsuk86 over 7 years ago
I am trying to use an external UART device as primary stdin/stdout console.
                   │ │                ( ) psu_uart_0                     │ │
                   │ │                ( ) axi_uart16550_0                │ │
                   │ │                (X) axi_uartlite_0                 │ │
                   │ │                ( ) manual      │ │
If psu_uart_0 is selected as primary stdin/stdout consol, system boots from SD, eMMC... and I can interact throught serial console. When Linux Boots, the external UARTs are available:
If the axi_uart16550_0 or axi_uartlite_0 devices is selected, Linux does not boot (even bitfile is not loaded).
    System: Avnet UltraZed-EG in IOCC board. Xilinx ZynqRegistered UltraScale+Tm MPSoC
    Petalinux version: 2012.2
    Vivado version: 2018.2
I am doing anything wrong? I attach in this thread all the info I consider may be useful. If you need additional info please let me know.
Is there any related issue with Petalinux?
Thanks!
The block design is:
pl.dtsi:
        amba_pl: amba_pl@0 {
            #address-cells = <2>;
            #size-cells = <2>;
            compatible = "simple-bus";
            ranges ;
            axi_dma_0: dma@80000000 {
                #dma-cells = <1>;
                clock-names = "s_axi_lite_aclk", "m_axi_sg_aclk", "m_axi_mm2s_aclk", "m_axi_s2mm_aclk";
                clocks = <&clk 71>, <&clk 71>, <&clk 71>, <&clk 71>;
                compatible = "xlnx,axi-dma-1.00.a";
                interrupt-names = "mm2s_introut", "s2mm_introut";
                interrupt-parent = <&gic>;
                interrupts = <0 89 4 0 90 4>;
                reg = <0x0 0x80000000 0x0 0x1000>;
                xlnx,addrwidth = <0x20>;
                xlnx,include-sg ;
                xlnx,sg-length-width = <0x17>;
                dma-channel@80000000 {
                    compatible = "xlnx,axi-dma-mm2s-channel";
                    dma-channels = <0x1>;
                    interrupts = <0 89 4>;
                    xlnx,datawidth = <0x20>;
                    xlnx,device-id = <0x0>;
                dma-channel@80000030 {
                    compatible = "xlnx,axi-dma-s2mm-channel";
                    interrupts = <0 90 4>;
            axi_uart16550_0: serial@80020000 {
                clock-frequency = <99999000>;
                clock-names = "s_axi_aclk";
                clocks = <&clk 71>;
                compatible = "xlnx,xps-uart16550-2.00.a", "ns16550a";
                current-speed = <115200>;
                device_type = "serial";
                interrupt-names = "ip2intc_irpt";
                interrupts = <0 92 4>;
                port-number = <1>;
                reg = <0x0 0x80020000 0x0 0x10000>;
                reg-offset = <0x1000>;
                reg-shift = <2>;
                xlnx,external-xin-clk-hz = <0x17d7840>;
                xlnx,external-xin-clk-hz-d = <0x19>;
                xlnx,has-external-rclk = <0x0>;
                xlnx,has-external-xin = <0x0>;
                xlnx,is-a-16550 = <0x1>;
                xlnx,s-axi-aclk-freq-hz-d = "99.999";
                xlnx,use-modem-ports = <0x1>;
                xlnx,use-user-ports = <0x1>;
            axi_uartlite_0: serial@80001000 {
                clocks = <&clk 71>;
                compatible = "xlnx,xps-uartlite-1.00.a";
                interrupt-names = "interrupt";
                interrupts = <0 91 1>;
                port-number = <0>;
                reg = <0x0 0x80001000 0x0 0x1000>;
                xlnx,baudrate = <0x1c200>;
                xlnx,data-bits = <0x8>;
                xlnx,odd-parity = <0x0>;
                xlnx,use-parity = <0x0>;
            psu_ctrl_ipi: PERIPHERAL@ff380000 {
                compatible = "xlnx,PERIPHERAL-1.0";
                reg = <0x0 0xff380000 0x0 0x80000>;
            psu_message_buffers: PERIPHERAL@ff990000 {
                reg = <0x0 0xff990000 0x0 0x10000>;
            M00_AXI_ps: M00_AXI_ps@80010000 {
                reg = <0x0 0x80010000 0x0 0x10000>;
system-top.dtsi
    /dts-v1/;
    /include/ "zynqmp.dtsi"
    /include/ "zynqmp-clk-ccf.dtsi"
    /include/ "pl.dtsi"
    /include/ "pcw.dtsi"
        chosen {
            bootargs = "earlycon clk_ignore_unused";
            stdout-path = "serial0:115200n8";
        aliases {
            ethernet0 = &gem3;
            i2c0 = &i2c1;
            serial0 = &axi_uartlite_0;
            serial1 = &axi_uart16550_0;
            serial2 = &uart0;
            spi0 = &qspi;
        memory {
            device_type = "memory";
            reg = <0x0 0x0 0x0 0x7ff00000>;
    #include "system-user.dtsi"
platform-auto.h
    /* uartlite - axi_uartlite_0 */
    #define XILINX_UARTLITE_BASEADDR    0x80001000
    #define CONFIG_BAUDRATE    115200
    #define TTYUL0    "ttyUL0=setenv stdout ttyUL0;setenv stdin ttyUL0\0"
    #define SERIAL_MULTI    "serial=setenv stdout serial;setenv stdin serial\0" "stdin=ttyUL0\0" "stdout=ttyUL0\0"
    #define CONSOLE_ARG "console=console=ttyUL0,115200\0"
    /* Extra U-Boot Env settings */
    #define CONFIG_EXTRA_ENV_SETTINGS \
        SERIAL_MULTI \
        CONSOLE_ARG \
        DFU_ALT_INFO_RAM \
        DFU_ALT_INFO_MMC \
        TTYUL0 \
  • oleb0n
    oleb0n over 6 years ago
    A year later I have the same problem, if I try to use PL UART as system console it fails to boot. Please share your solution if you found it image
