Ultra96 Hardware Design ROCKY PMIC
  • Subscribers 365 subscribers
  • Views 948 views
ROCKY PMIC
iwao
iwao over 6 years ago
The PMIC "IRPS5401MTRPBF" is on Ultra96.
So, please tell me how to program that device, and setting value.
Best Regerds
  • bhfletcher
    bhfletcher over 6 years ago +1
    The IRPS5401MTRPBF on the Ultra96-V2 comes pre-programmed. You do not need to program it. There is a bit more information in this blog: Infineon PMIC updates to Avnet products Bryan
  • bhfletcher
    Bryan
  • iwao
    iwao over 6 years ago in reply to bhfletcher
    Thank you for your reply.
    I need to buy it.
    So, please tell me the PreProgramed part number to buy.
    Best regards.
  • bhfletcher
    bhfletcher over 6 years ago in reply to iwao
    This is not a part number that can be purchased pre-programmed from the manufacturer. When we manufacture this board, we use Avnet's Programming Center to program blank parts for us.
    https://www.avnet.com/wps/portal/us/solutions/logistics/value-add-and-integration/device-programming-and-modifications/
    I believe you may be able to order this same pre-programmed part as we have a specific part number assigned to our specific project. This is the part number for the Rocky with Avnet's 10/30/2019 datecode programming. You may be able to use the web inquiry form above and the part number below to see if this can be programmed for you.
    AVT~IRPS5401MTRPBF/BKN~464093~PM
    The other alternative is to read the blog that I linked in my previous reply and request the programming code where you could program blank parts yourself.
    Bryan
