Ultra96 Hardware Design Booting Ultra96v2 kernel in qemu
  • Subscribers 364 subscribers
  • Views 2713 views
  • ultra96
helmotz
helmotz over 6 years ago
Hello to everybody,
I'm experimenting with the vitis 2019.2 flow on my ultra96v2.
I downloaded the petalinux, hdl, bdf and vitis projects and I created the hardware project, the bsp and the sdk simply going in vitis and using the Makefile.
After I went to the petalinux project and I used petalinux-build to create qemu dtb files.
Finally I created an image with two partitions: a vfat partition and an ext3 partition.
I put image.ub in the first partition and I expanded rootfs.tar.gz in the ext3 partition.
The name of the image is image.img .
Then I tried to boot qemu with the command:
petalinux-boot --qemu --u-boot --qemu-args "-sd ./image.img -m 2G"
I get the following output:
INFO: sourcing build tools
INFO: No DTB has been specified, use the default one "/home/fchirico/Workspaces/petalinux/projects/ultra96v2_oob_2019_2/images/linux/system.dtb".
INFO: Starting microblaze QEMU
INFO: Starting the above QEMU command in the background
INFO:  qemu-system-microblazeel -M microblaze-fdt   -serial mon:stdio -serial /dev/null -display none -kernel /home/fchirico/Workspaces/petalinux/projects/ultra96v2_oob_2019_2/pre-built/linux/images/pmu_rom_qemu_sha3.elf -device loader,file=/home/fchirico/Workspaces/petalinux/projects/ultra96v2_oob_2019_2/images/linux/pmufw.elf      -hw-dtb /mnt/old_root/storage/fchirico/Workspaces/petalinux/projects/ultra96v2_oob_2019_2/images/linux/zynqmp-qemu-multiarch-pmu.dtb -machine-path /tmp/tmp.kAL4rJ7rxf -device loader,addr=0xfd1a0074,data=0x1011003,data-len=4 -device loader,addr=0xfd1a007C,data=0x1010f03,data-len=4
qemu-system-microblazeel: Failed to connect socket /tmp/tmp.kAL4rJ7rxf/qemu-rport-_pmu@0: No such file or directory
qemu-system-microblazeel: info: QEMU waiting for connection on: disconnected:unix:/tmp/tmp.kAL4rJ7rxf/qemu-rport-_pmu@0,server
INFO: Set QEMU tftp to /mnt/old_root/storage/fchirico/Workspaces/petalinux/projects/ultra96v2_oob_2019_2/images/linux
INFO: TCP PORT is free
INFO: Starting aarch64 QEMU
INFO:  qemu-system-aarch64 -M arm-generic-fdt   -serial /dev/null -serial mon:stdio -serial /dev/null -serial /dev/null -display none -device loader,file=/home/fchirico/Workspaces/petalinux/projects/ultra96v2_oob_2019_2/images/linux/bl31.elf,cpu-num=0 -device loader,file=/home/fchirico/Workspaces/petalinux/projects/ultra96v2_oob_2019_2/images/linux/u-boot.elf -gdb tcp::9000 -dtb /home/fchirico/Workspaces/petalinux/projects/ultra96v2_oob_2019_2/images/linux/system.dtb    -hw-dtb /mnt/old_root/storage/fchirico/Workspaces/petalinux/projects/ultra96v2_oob_2019_2/images/linux/zynqmp-qemu-multiarch-arm.dtb -machine-path /tmp/tmp.kAL4rJ7rxf -global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=true -sd ./image.img -m 2G
WARNING: Image format was not specified for './image.img' and probing guessed raw.
         Automatically detecting the format is dangerous for raw images, write operations on block 0 will be restricted.
         Specify the 'raw' format explicitly to remove the restrictions.
QEMU 2.11.1 monitor - type 'help' for more information
(qemu) audio: Could not init `oss' audio driver
PMU Firmware 2019.2 Apr 28 2020   08:21:48
PMU_ROM Version: xpbr-v8.1.0-0
NOTICE:  ATF running on XCZUUNKN/QEMU v4/RTL0.0 at 0xfffea000
NOTICE:  BL31: Secure code at 0x60000000
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v2.0(release):xilinx-v2019.1-12-g713dace9
NOTICE:  BL31: Built : 07:52:43, Apr 28 2020
PMUFW: v1.1
U-Boot 2019.01 (Apr 28 2020 - 07:51:08 +0000)
Model: Avnet Ultra96 Rev1
Board: Xilinx ZynqMP
DRAM:  2 GiB
EL Level: EL2
Chip ID: unknown
MMC:   mmc@ff160000: 0, mmc@ff170000: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In:    serial@ff010000
Out:   serial@ff010000
Err:   serial@ff010000
Bootmode: JTAG_MODE
Reset reason:
Net:   No ethernet found.
U-BOOT for ultra96v2-oob-2019-2
Hit any key to stop autoboot:  0
Device: mmc@ff160000
Manufacturer ID: aa
OEM: 5859
Bus Speed: 17361111
Mode : SD Legacy
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 9.5 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
18479356 bytes read in 3616 ms (4.9 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
   Using 'conf@system-top.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x10000108
     Data Size:    18424320 Bytes = 17.6 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   e22e3af6cdb6990ceb62b256643993aac64aa7c8
   Verifying Hash Integrity ... sha1+ OK
## Loading fdt from FIT Image at 10000000 ...
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x1119240c
     Data Size:    53116 Bytes = 51.9 KiB
     Hash algo:    sha1
     Hash value:   a0516993c81365806da480bd793a3b97991fe6a1
   Booting using the fdt blob at 0x1119240c
   Loading Kernel Image ... OK
   Loading Device Tree to 0000000007ff0000, end 0000000007ffff7b ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 4.19.0-xilinx-v2019.2 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Tue Apr 28 07:49:56 UTC 2020
[    0.000000] Machine model: Avnet Ultra96 Rev1
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff010000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Failed to reserve 1024 MiB
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0
[    0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52568 r8192 d29352 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 843419
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 512771
[    0.000000] Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2027500K/2079744K available (10940K kernel code, 648K rwdata, 5504K rodata, 832K init, 514K bss, 52244K reserved, 0K cma-reserved)
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: RCU event tracing is enabled.
[    0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] irq-xilinx: /amba/axi-interrupt-ctrl: num_irq=32, edge=0x0
[    0.000000] arch_timer: cp15 timer(s) running at 65.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xefdb196da, max_idle_ns: 440795204367 ns
[    0.000202] sched_clock: 56 bits at 65MHz, resolution 15ns, wraps every 2199023255550ns
[    0.013867] Console: colour dummy device 80x25
[    0.023762] Calibrating delay loop (skipped), value calculated using timer frequency.. 130.00 BogoMIPS (lpj=260000)
[    0.024576] pid_max: default: 32768 minimum: 301
[    0.032221] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.032739] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.099192] ASID allocator initialised with 32768 entries
[    0.117509] rcu: Hierarchical SRCU implementation.
[    0.122199] EFI services will not be available.
[    0.125202] smp: Bringing up secondary CPUs ...
[    0.169741] Detected VIPT I-cache on CPU1
[    0.174940] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.209901] Detected VIPT I-cache on CPU2
[    0.210788] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.259990] Detected VIPT I-cache on CPU3
[    0.260435] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.274436] smp: Brought up 1 node, 4 CPUs
[    0.277236] SMP: Total of 4 processors activated.
[    0.277907] CPU features: detected: 32-bit EL0 Support
[    0.298478] CPU: All CPU(s) started at EL2
[    0.304791] alternatives: patching kernel code
[    0.346663] devtmpfs: initialized
[    0.471529] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.473244] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.483549] xor: measuring software checksum speed
[    0.543754]    8regs     :  1839.000 MB/sec
[    0.602623]    8regs_prefetch:  1648.000 MB/sec
[    0.655423]    32regs    :  1610.000 MB/sec
[    0.781505]    32regs_prefetch:  1210.000 MB/sec
[    0.782033] xor: using function: 8regs (1839.000 MB/sec)
[    0.782685] pinctrl core: initialized pinctrl subsystem
[    0.851011] NET: Registered protocol family 16
[    0.882233] audit: initializing netlink subsys (disabled)
[    0.897394] audit: type=2000 audit(0.476:1): state=initialized audit_enabled=0 res=1
[    0.923532] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.927743] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.970593] DMA: preallocated 256 KiB pool for atomic allocations
[    1.445743] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    1.647008] raid6: int64x1  gen()   314 MB/s
[    1.733804] raid6: int64x1  xor()   322 MB/s
[    1.830716] raid6: int64x2  gen()   518 MB/s
[    1.930693] raid6: int64x2  xor()   169 MB/s
[    2.084201] raid6: int64x4  gen()   597 MB/s
[    2.183807] raid6: int64x4  xor()   329 MB/s
[    2.297486] raid6: int64x8  gen()   900 MB/s
[    2.422534] raid6: int64x8  xor()   688 MB/s
[    2.512566] raid6: neonx1   gen()   132 MB/s
[    2.605763] raid6: neonx1   xor()   261 MB/s
[    2.684267] raid6: neonx2   gen()   388 MB/s
[    2.782238] raid6: neonx2   xor()   252 MB/s
[    2.877446] raid6: neonx4   gen()   262 MB/s
[    2.979925] raid6: neonx4   xor()   327 MB/s
[    3.068337] raid6: neonx8   gen()   214 MB/s
[    3.156176] raid6: neonx8   xor()   162 MB/s
[    3.156703] raid6: using algorithm int64x8 gen() 900 MB/s
[    3.157003] raid6: .... xor() 688 MB/s, rmw enabled
[    3.157342] raid6: using neon recovery algorithm
[    3.271880] SCSI subsystem initialized
[    3.354216] usbcore: registered new interface driver usbfs
[    3.355111] usbcore: registered new interface driver hub
[    3.357825] usbcore: registered new device driver usb
[    3.359094] media: Linux media interface: v0.10
[    3.359611] videodev: Linux video capture interface: v2.00
[    3.360511] pps_core: LinuxPPS API ver. 1 registered
[    3.360987] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.365721] PTP clock support registered
[    3.368577] EDAC MC: Ver: 3.0.0
[    3.396404] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
[    3.409501] FPGA manager framework
[    3.417002] Advanced Linux Sound Architecture Driver Initialized.
[    3.431658] Bluetooth: Core ver 2.22
[    3.458903] NET: Registered protocol family 31
[    3.459263] Bluetooth: HCI device and connection manager initialized
[    3.459946] Bluetooth: HCI socket layer initialized
[    3.460355] Bluetooth: L2CAP socket layer initialized
[    3.461064] Bluetooth: SCO socket layer initialized
[    3.599427] clocksource: Switched to clocksource arch_sys_counter
[    3.601413] VFS: Disk quotas dquot_6.6.0
[    3.604727] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    4.013528] NET: Registered protocol family 2
[    4.030228] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[    4.031666] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    4.033131] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    4.034770] TCP: Hash tables configured (established 16384 bind 16384)
[    4.040123] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    4.040992] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    4.043351] NET: Registered protocol family 1
[    4.062097] RPC: Registered named UNIX socket transport module.
[    4.067235] RPC: Registered udp transport module.
[    4.071147] RPC: Registered tcp transport module.
[    4.085872] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    4.169944] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    4.212573] hw perfevents: enabled with armv8_pmuv3 PMU driver, 1 counters available
[    4.252193] Initialise system trusted keyrings
[    4.275948] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    4.358486] NFS: Registering the id_resolver key type
[    4.377088] Key type id_resolver registered
[    4.377408] Key type id_legacy registered
[    4.377828] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    4.383044] jffs2: version 2.2. (NAND) Copyright 2001-2006 Red Hat, Inc.
[    7.908569] NET: Registered protocol family 38
[    8.105522] Key type asymmetric registered
[    8.106253] Asymmetric key parser 'x509' registered
[    8.107712] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    8.108824] io scheduler noop registered
[    8.109356] io scheduler deadline registered
[    8.110211] io scheduler cfq registered (default)
[    8.111622] io scheduler mq-deadline registered
[    8.112227] io scheduler kyber registered
[   11.338021] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[   11.390494] a0010000.serial: ttyS3 at MMIO 0xa0011000 (irq = 83, base_baud = 6250000) is a 16550A
[   11.413829] a0020000.serial: ttyS1 at MMIO 0xa0021000 (irq = 84, base_baud = 6250000) is a 16550A
[   11.711275] brd: module loaded
[   11.833266] loop: module loaded
[   11.852988] mtdoops: mtd device (mtddev=name/number) must be supplied
[   11.897113] libphy: Fixed MDIO Bus: probed
[   11.918523] tun: Universal TUN/TAP device driver, 1.6
[   11.968806] CAN device driver interface
[   11.987243] usbcore: registered new interface driver asix
[   11.987897] usbcore: registered new interface driver ax88179_178a
[   11.988537] usbcore: registered new interface driver cdc_ether
[   11.989123] usbcore: registered new interface driver net1080
[   11.989719] usbcore: registered new interface driver cdc_subset
[   11.990382] usbcore: registered new interface driver zaurus
[   11.991085] usbcore: registered new interface driver cdc_ncm
[   12.005649] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   12.006492] ehci-pci: EHCI PCI platform driver
[   12.016300] usbcore: registered new interface driver uas
[   12.017907] usbcore: registered new interface driver usb-storage
[   12.026243] gadgetfs: USB Gadget filesystem, version 24 Aug 2004
[   12.045922] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[   12.047714] i2c /dev entries driver
[   12.077192] usbcore: registered new interface driver uvcvideo
[   12.078103] USB Video Class driver (1.1.1)
[   12.099837] Bluetooth: HCI UART driver ver 2.3
[   12.100574] Bluetooth: HCI UART protocol H4 registered
[   12.101275] Bluetooth: HCI UART protocol BCSP registered
[   12.104000] Bluetooth: HCI UART protocol LL registered
[   12.104342] Bluetooth: HCI UART protocol ATH3K registered
[   12.104935] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   12.105802] Bluetooth: HCI UART protocol Intel registered
[   12.106360] Bluetooth: HCI UART protocol QCA registered
[   12.107387] usbcore: registered new interface driver bcm203x
[   12.109293] usbcore: registered new interface driver bpa10x
[   12.109792] usbcore: registered new interface driver bfusb
[   12.116670] usbcore: registered new interface driver btusb
[   12.117124] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[   12.117872] usbcore: registered new interface driver ath3k
[   12.130058] EDAC MC: ECC not enabled
[   12.143934] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED)
[   12.149964] EDAC ZynqMP-OCM: ECC not enabled - Disabling EDAC driver
[   12.161130] pwrseq_simple sdio_pwrseq: mmc failed to get default resetn GPIO
[   12.162503] pwrseq_simple sdio_pwrseq: mmc failed to get default chip_en GPIO
[   12.169890] sdhci: Secure Digital Host Controller Interface driver
[   12.170476] sdhci: Copyright(c) Pierre Ossman
[   12.170770] sdhci-pltfm: SDHCI platform and OF driver helper
[   12.211596] ledtrig-cpu: registered to indicate activity on CPUs
[   12.213126] zynqmp_firmware_probe Platform Management API v1.1
[   12.213558] zynqmp_firmware_probe Trustzone version v1.0
[   12.385286] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[   12.963856] hrtimer: interrupt took 80963062 ns
[   14.174728] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
[   14.209558] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[   14.213424] zynqmp_aes zynqmp_aes: AES Successfully Registered
[   14.213424]
[   14.218875] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[   14.234872] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[   14.239778] usbcore: registered new interface driver usbhid
[   14.240093] usbhid: USB HID core driver
[   14.248184] xlnk xlnk: Major 242
[   14.251669] xlnk xlnk: xlnk driver loaded
[   14.252352] xlnk xlnk: xlnk_pdev is not null
[   14.365393] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[   14.394184] usbcore: registered new interface driver snd-usb-audio
[   14.444827] pktgen: Packet Generator for packet performance testing. Version: 2.75
[   14.570618] Initializing XFRM netlink socket
[   14.575589] NET: Registered protocol family 10
[   14.625967] Segment Routing with IPv6
[   14.653052] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[   14.675096] NET: Registered protocol family 17
[   14.680275] NET: Registered protocol family 15
[   14.681640] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   14.693426] can: controller area network core (rev 20170425 abi 9)
[   14.695675] NET: Registered protocol family 29
[   14.696208] can: raw protocol (rev 20170425)
[   14.696628] can: broadcast manager protocol (rev 20170425 t)
[   14.700696] can: netlink gateway (rev 20170425) max_hops=1
[   14.715254] Bluetooth: RFCOMM TTY layer initialized
[   14.716718] Bluetooth: RFCOMM socket layer initialized
[   14.717607] Bluetooth: RFCOMM ver 1.11
[   14.722332] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.726373] Bluetooth: BNEP filters: protocol multicast
[   14.726913] Bluetooth: BNEP socket layer initialized
[   14.727303] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[   14.727914] Bluetooth: HIDP socket layer initialized
[   14.741758] 9pnet: Installing 9P2000 support
[   14.742589] Key type dns_resolver registered
[   14.771115] registered taskstats version 1
[   14.774511] Loading compiled-in X.509 certificates
[   14.797133] Btrfs loaded, crc32c=crc32c-generic
[   14.935018] ff000000.serial: ttyPS2 at MMIO 0xff000000 (irq = 41, base_baud = 10416666) is a xuartps
[   14.988148] ff010000.serial: ttyPS0 at MMIO 0xff010000 (irq = 42, base_baud = 2480158) is a xuartps
[   14.994570] console [ttyPS0] enabled
[   15.004960] bootconsole [cdns0] disabled
[   15.023517] GPIO IRQ not connected
[   15.023925] XGpio: gpio@a0030000: registered, base is 510
[   15.024396] GPIO IRQ not connected
[   15.026400] XGpio: gpio@a0030000: dual channel registered, base is 508
[   15.033870] GPIO IRQ not connected
[   15.049417] XGpio: gpio@a0040000: registered, base is 507
[   15.064363] GPIO IRQ not connected
[   15.066079] XGpio: gpio@a0050000: registered, base is 506
[   15.067139] GPIO IRQ not connected
[   15.071500] XGpio: gpio@a0050000: dual channel registered, base is 505
[   15.105210] of-fpga-region fpga-full: FPGA Region probed
[   15.228209] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[   15.247900] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[   15.249650] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[   15.251548] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[   15.254081] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[   15.275314] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[   15.277516] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[   15.283699] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[   15.288304] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[   15.310324] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[   15.317068] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[   15.343782] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[   15.345692] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[   15.348123] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[   15.349852] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[   15.352290] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[   15.366577] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[   15.392352] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[   15.469053] zynqmp_clk_divider_set_rate() set divider failed for ams_ref_div1, ret = -13
[   15.781968] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Failed to get required clock freq
[   15.795268] xilinx-dp-snd-codec: probe of fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0 failed with error -22
[   15.805702] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[   15.834114] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[   15.839202] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
[   15.841287] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[   15.857890] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   15.858481] [drm] No driver support for vblank timestamp query.
[   15.862813] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008bef538)
[   16.248779] Console: switching to colour frame buffer device 128x48
[   16.270458] zynqmp-display fd4a0000.zynqmp-display: fb0:  frame buffer device
[   16.289919] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[   16.319917] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[   16.327734] zynqmp_gpd_attach_dev() domain6 request failed for node 35: -13
[   16.328712] cdns-spi ff040000.spi: failed to add to PM domain domain6: -13
[   16.329616] cdns-spi: probe of ff040000.spi failed with error -13
[   16.334911] zynqmp_gpd_attach_dev() domain7 request failed for node 36: -13
[   16.347914] cdns-spi ff050000.spi: failed to add to PM domain domain7: -13
[   16.351635] cdns-spi: probe of ff050000.spi failed with error -13
[   16.363989] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[   16.387852] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[   16.397499] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[   16.402477] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[   16.474326] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[   16.476644] WARNING: CPU: 3 PID: 217 at include/linux/dma-mapping.h:516 dwc3_alloc_event_buffers+0x138/0x1b8
[   16.477839] Modules linked in:
[   16.478437] CPU: 3 PID: 217 Comm: kworker/3:2 Not tainted 4.19.0-xilinx-v2019.2 #1
[   16.479346] Hardware name: Avnet Ultra96 Rev1 (DT)
[   16.482491] Workqueue: events deferred_probe_work_func
[   16.494792] pstate: 60000005 (nZCv daif -PAN -UAO)
[   16.495411] pc : dwc3_alloc_event_buffers+0x138/0x1b8
[   16.497122] lr : dwc3_alloc_event_buffers+0x6c/0x1b8
[   16.497776] sp : ffffff80097bb6e0
[   16.498378] x29: ffffff80097bb6e0 x28: 0000000000000000
[   16.499247] x27: 0000000000000000 x26: 0000000000000000
[   16.499857] x25: ffffffc07c69aa38 x24: 0000000000001000
[   16.501453] x23: ffffffc07c694410 x22: ffffff8008b37000
[   16.501805] x21: ffffffc07c69b818 x20: ffffff8009178648
[   16.502178] x19: ffffffc07c69aa18 x18: 0000000000000010
[   16.502540] x17: 0000000000000000 x16: 0000000000000000
[   16.502914] x15: ffffffffffffffff x14: ffffff8009178648
[   16.503281] x13: ffffff808921af0f x12: ffffff800921af17
[   16.503640] x11: 0000000000000001 x10: ffffff80091f8040
[   16.504053] x9 : 0000000000000000 x8 : ffffffc07c6d6000
[   16.504421] x7 : 0000000000000000 x6 : 000000000000003f
[   16.504781] x5 : 0000000000000040 x4 : ffffffc07c6946a0
[   16.505148] x3 : 0000000000000000 x2 : 0000000000000001
[   16.505593] x1 : ffffffc07c69aa00 x0 : 0000000000000000
[   16.506140] Call trace:
[   16.506417]  dwc3_alloc_event_buffers+0x138/0x1b8
[   16.506773]  dwc3_probe+0x7b4/0xbb0
[   16.507026]  platform_drv_probe+0x50/0xa0
[   16.507576]  really_probe+0x1c8/0x280
[   16.507853]  driver_probe_device+0x54/0xe8
[   16.508144]  __device_attach_driver+0xb8/0xe8
[   16.508403]  bus_for_each_drv+0x78/0xc8
[   16.508676]  __device_attach+0xd4/0x130
[   16.508940]  device_initial_probe+0x10/0x18
[   16.509252]  bus_probe_device+0x90/0x98
[   16.509529]  device_add+0x334/0x608
[   16.509798]  of_device_add+0x58/0x68
[   16.510051]  of_platform_device_create_pdata+0xac/0x108
[   16.510409]  of_platform_bus_create+0x294/0x390
[   16.510731]  of_platform_populate+0x74/0xd8
[   16.511025]  dwc3_of_simple_probe+0x3fc/0x528
[   16.511334]  platform_drv_probe+0x50/0xa0
[   16.511623]  really_probe+0x1c8/0x280
[   16.517533]  driver_probe_device+0x54/0xe8
[   16.518261]  __device_attach_driver+0xb8/0xe8
[   16.518781]  bus_for_each_drv+0x78/0xc8
[   16.519220]  __device_attach+0xd4/0x130
[   16.519659]  device_initial_probe+0x10/0x18
[   16.520138]  bus_probe_device+0x90/0x98
[   16.520563]  deferred_probe_work_func+0x6c/0xa0
[   16.521136]  process_one_work+0x1e4/0x340
[   16.521922]  worker_thread+0x248/0x488
[   16.523125]  kthread+0x124/0x128
[   16.530775]  ret_from_fork+0x10/0x18
[   16.531442] ---[ end trace bcc575cea71f9987 ]---
[   16.532413] dwc3 fe200000.dwc3: swiotlb: coherent allocation failed, size=4096
[   16.533031] CPU: 3 PID: 217 Comm: kworker/3:2 Tainted: G        W         4.19.0-xilinx-v2019.2 #1
[   16.533648] Hardware name: Avnet Ultra96 Rev1 (DT)
[   16.534056] Workqueue: events deferred_probe_work_func
[   16.534451] Call trace:
[   16.537592]  dump_backtrace+0x0/0x148
[   16.538065]  show_stack+0x14/0x20
[   16.538516]  dump_stack+0x90/0xb4
[   16.550235]  swiotlb_alloc+0x160/0x168
[   16.558732]  __dma_alloc+0xa8/0x1e0
[   16.558963]  dwc3_alloc_event_buffers+0xd0/0x1b8
[   16.559184]  dwc3_probe+0x7b4/0xbb0
[   16.559360]  platform_drv_probe+0x50/0xa0
[   16.559591]  really_probe+0x1c8/0x280
[   16.559852]  driver_probe_device+0x54/0xe8
[   16.560132]  __device_attach_driver+0xb8/0xe8
[   16.560436]  bus_for_each_drv+0x78/0xc8
[   16.560716]  __device_attach+0xd4/0x130
[   16.560970]  device_initial_probe+0x10/0x18
[   16.561266]  bus_probe_device+0x90/0x98
[   16.561536]  device_add+0x334/0x608
[   16.571784]  of_device_add+0x58/0x68
[   16.572115]  of_platform_device_create_pdata+0xac/0x108
[   16.572601]  of_platform_bus_create+0x294/0x390
[   16.573161]  of_platform_populate+0x74/0xd8
[   16.573636]  dwc3_of_simple_probe+0x3fc/0x528
[   16.574133]  platform_drv_probe+0x50/0xa0
[   16.574615]  really_probe+0x1c8/0x280
[   16.575570]  driver_probe_device+0x54/0xe8
[   16.576163]  __device_attach_driver+0xb8/0xe8
[   16.586704]  bus_for_each_drv+0x78/0xc8
[   16.587001]  __device_attach+0xd4/0x130
[   16.587280]  device_initial_probe+0x10/0x18
[   16.587557]  bus_probe_device+0x90/0x98
[   16.587741]  deferred_probe_work_func+0x6c/0xa0
[   16.587957]  process_one_work+0x1e4/0x340
[   16.588147]  worker_thread+0x248/0x488
[   16.588329]  kthread+0x124/0x128
[   16.588497]  ret_from_fork+0x10/0x18
[   16.593354] dwc3 fe200000.dwc3: can't allocate event buffer
[   16.598563] dwc3 fe200000.dwc3: failed to allocate event buffers
[   16.600154] dwc3: probe of fe200000.dwc3 failed with error -12
[   16.606018] zynqmp_gpd_attach_dev() domain9 request failed for node 23: -13
[   16.611013] dwc3-of-simple ff9e0000.usb1: failed to add to PM domain domain9: -13
[   16.612014] dwc3-of-simple: probe of ff9e0000.usb1 failed with error -13
[   16.715300] pca954x 0-0075: probe failed
[   16.716681] i2c i2c-0: Failed to register i2c client pca9548 at 0x75 (-16)
[   16.718509] i2c i2c-0: of_i2c: Failure registering /amba/i2c@ff030000/i2cswitch@75
[   16.720312] i2c i2c-0: Failed to create I2C device for /amba/i2c@ff030000/i2cswitch@75
[   16.721412] cdns-i2c ff030000.i2c: 100 kHz mmio ff030000 irq 31
[   16.768219] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
[   16.778513] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer with timeout 10s
[   16.792882] pwrseq_simple sdio_pwrseq: mmc succesfully got gpio_resetn
[   16.801619] pwrseq_simple sdio_pwrseq: mmc succesfully got gpio_chip_en
[   16.821453] zynqmp_gpd_attach_dev() domain11 request failed for node 39: -13
[   16.822059] sdhci-arasan ff160000.mmc: failed to add to PM domain domain11: -13
[   16.838177] sdhci-arasan: probe of ff160000.mmc failed with error -13
[   16.852550] sdhci-arasan ff170000.mmc: allocated mmc-pwrseq
[   16.856983] sdhci-arasan ff170000.mmc: Linked as a consumer to regulator.1
[   16.938518] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[   17.014546] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
[   17.025705] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
[   17.081782] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   17.114983] rtc_zynqmp ffa60000.rtc: setting system clock to 2020-04-28 18:17:55 UTC (1588097875)
[   17.115874] of_cfs_init
[   17.120045] of_cfs_init: OK
[   17.125085] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   17.140038] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
[   17.592579] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   17.593410] clk: Not disabling unused clocks
[   17.593937] ALSA device list:
[   17.594172]   No soundcards found.
[   17.620499] Waiting for root device /dev/mmcblk0p2...
[   17.621914] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   17.622871] cfg80211: failed to load regulatory.db
I notice that I get many kernel errors and, moreover, it seems that device /dev/mmcblk0p2 (second partition on SD) is not visible.
Did I miss any steps?
Thank you in advance,
Francesco
  • narrucmot
    narrucmot over 6 years ago
    This OS image (ultra96v2_oob_2019_2) for the Ultra96-V2 board has not been tested with qemu.  You might want to check out Xilinx UG1169 for some assistance.
    --Tom
