Ultra96 Hardware Design Ultra96 Display Example designs
  • Subscribers 364 subscribers
  • Views 972 views
  • ultra96
400garrison
400garrison over 5 years ago
We are interested in any suggestions for a display to use with Avnet’s 96Boards Dual Camera Mezzanine. We purchased a Raspberry Pi display since it seems like a popular DSI option and the pinout matches the Mezzanine’s display connector.
Unfortunately, we are having trouble getting the display up and running. One issue is that the drivers for the display are very well hidden inside the corresponding Raspberry Pi code.  Our problem may be a combination of the drivers and our display path (which we recently discovered a potential reset issue with) and so we may still solve it. Are there any other DSI displays that work will the Mezzanine board (and perhaps a corresponding example design)?
  • mindaugas
    mindaugas over 5 years ago
    Hi Adam,
    Have you considered using DisplayPort instead of MIPI DSI? Ultra96 has dedicated mini DisplayPort connector. I think that 10-inch Zed Touch Display Kit or any other DisplayPort screen would be working fine. You could also connect HDMI Raspberry PI or other HDMI screen by using active mini DisplayPort to HDMI adapter.
    With best regards,
    Mindaugas Sulcas
