Ultra96 Hardware Design petalinux-config Xfce
  • Subscribers 365 subscribers
  • Views 1509 views
raiatea
raiatea over 8 years ago
I have used Petalinux v2018.2 with the Ultra96 BSP, and ended with the default Matchbox instead of Enlightenment of the demo image. It seems Enlightenment is blacklisted in the last openembedded release, so I would like to use Xfce instead, anyway I prefer to use something based on Qt or GTK.
The x-window-manager and x-session-manager recipes have several providers: mini-x-session, matchbox and xfce with various priorities.
In my last build attempt I had both matchbox and xfce, with mixed linux x configuration files. Before trying to configure in the target OS, I would like to configure petalinux.
What is the best way to specify the priority of Xfce ? edit openembedded or meta-xilinx files, or create meta-user or local.conf files, or is it possible to do that in petalinux-config ?
  • bhfletcher
    0 bhfletcher over 8 years ago
    Hello @raiatea,
    Did you have any luck with Xfce? I have not heard of anyone who has done this yet, but I am interested to hear your results. Is there a reason why you do not prefer Matchbox?
    Bryan
  • raiatea
    0 raiatea over 6 years ago in reply to bhfletcher
    Reason of the choice: Xfce supports more windows than Matchbox.
    It is almost working, but the display is very sluggish, and OpenGL demos (tricube from ug1209 and SDKOpenGLES) are rendering at around 5 FPS.
    Although the Mali driver is installed, it is not obvious that X11 is hardware accelerated.
