Ultra96 Hardware Design Default Image - Networking (usb and wifi)
  • Subscribers 365 subscribers
  • Views 602 views
andycap
andycap over 8 years ago
Hi Guys,
I have networking over usb and also the Ultra96 connecting to my wifi at boot, the steps I have taken seem to be a bit of a hack though so I am wondering what the correct way of doing this is!
To get it working I had to do the following:
1. Add /etc/modules file containing:
  g_ether
2. Edit /etc/wpa_supplicant.conf and make it read only:
  ctrl_interface=/var/run/wpa_supplicant
  ctrl_interface_group=0
  update_config=1
  network={
    ssid="SSID"
    scan_ssid=1
    key_mgmt=WPA-PSK
    psk="PASSWORD"
3. add /etc/rcS.d/S99usbetherstart.sh containing
  sudo ifconfig usb0 192.168.3.1 netmask 255.255.255.0
  ifup wlan0
Anyone know the correct way of doing this?
Many thanks
Andy
  • narrucmot
    0 narrucmot over 8 years ago
    Your method looks correct to me.  It is common in Linux to need to edit those files to achieve the desired effect of booting what interfaces (in this case USB Ethernet and WiFi) you want configured in certain ways.  If your board now boots the way you need it to, connected by default to the SSID you specified, then I would consider your method a success!
    Cheers!
    Tom
  • andycap
    0 andycap over 8 years ago
    Hi Tom,
    Thanks for the info.
    The main issue I have is that I have to set  /etc/wpa_supplicant.conf to readonly otherwise something at startup re-writes it.
    You don;t by any chance now what is doing that?
    Cheeers
    Andy
