Ultra96 Hardware Design minidp to hdmi video
  • Subscribers 366 subscribers
  • Views 1059 views
mphillips53
mphillips53 over 8 years ago
Using a minidp to hdmi adapter connected to my crt, I am unable to boot to a desktop.  I tried two hdmi cables and two crts.  I get the following via dmesg:
[    7.608271] xilinx-drm xilinx_drm: No connectors reported connected with modes
[    7.615433] [drm] Cannot find any crtc or sizes - going 1024x768
[    7.627470] Console: switching to colour frame buffer device 128x48
[    7.638254] xilinx-drm xilinx_drm: fb0:  frame buffer device
[    7.656460] [drm] Initialized xilinx_drm 1.0.0 20130509 on minor 0
I am able to ssh to the server.  Does anyone have a solution to this issue?
Which passive or active minidp to HDMI adapters have been known to  work?
  • koremsen
    0 koremsen over 8 years ago
    I tried Xilinx ZCU102 board with DP-to-HDMI converter but no luck.
    Ultra96 board maight have the same silicon bug causing the failure of DP to HDMI conversion as descibed in AR# 67462:
    https://www.xilinx.com/support/answers/67462.html
  • koremsen
    0 koremsen over 8 years ago in reply to koremsen
    Following document specifies an active mini-DP-to-HDMI adapter (http://ableconn.com/products_2.php?gid=42) working with Ultra96 board.
    http://zedboard.org/sites/default/files/documentations/Ultra96_Accessories_180502.pdf
  • mphillips53
    0 mphillips53 over 8 years ago in reply to koremsen
    I ordered the adapter from Amazon.  In two more days, I will know if this issue is resolved.
  • mphillips53
    0 mphillips53 over 8 years ago in reply to mphillips53
    Received and installed adapter.  This issue is happily closed.  Thanks.
