Ultra96 Hardware Design Power Supplies
  • Subscribers 364 subscribers
  • Views 495 views
Power Supplies
bhfletcher
bhfletcher over 8 years ago
We have a new 4A/48W power supply for Ultra96 in stock, so I thought I would summarize the 3 supplies that we have available for Ultra96. Note that the power supply must be purchased separately from the Ultra96.
AES-ACC-U96-PWR -- 2A, 24W US-plug supply:
  •   http://avnet.me/96BoardPower2A
  •   https://www.newark.com/avnet/aes-acc-u96-pwr/power-supply-kit-12v-2a-us-plug/dp/69AC5609
  •   Description: AES-ACC-U96-PWR is the lowest-cost 96Boards-compatible power supply from Avnet that supplies 12V @ 2A. It has a US plug and supports 100-240 VAC. This power supply recommended for designs that do not consume much power through the expansion mezzanines or USB 3.0 host connectors.
 25HK-AB-120A250-CP6 -- 2.5A, 30W International-plug supply:
  •   https://uk.farnell.com/ideal-power/25hk-ab-120a250-cp6/adaptor-ac-dc-12v-2-5a/dp/2725685
  •   Description: Universal power supply with multiple plug options. High reliability. 4x Interchangeable AC plugs (Australia, Europe, UK and US). Supplied with 8x output connectors.
 AES-ACC-U96-4APWR -- 4A, 48W International-plug supply:
  •   http://avnet.me/96BoardPower4A
  •   https://uk.farnell.com/avnet/aes-acc-u96-4apwr/power-supply-kit-12v-4a/dp/2921438
  •   https://www.newark.com/avnet/aes-acc-u96-4apwr/ext-96boards-compliant-power-supply/dp/72AC4938
  •   Description: AES-ACC-U96-4APWR is the highest power 96Boards-compatible power supply from Avnet that supplies 12V @ 4A. It ships with an international plug set and supports 100-240 VAC. This power supply is recommended for designs that may consume power through the expansion mezzanines or USB 3.0 host connectors.
Bryan
