Ultra96 Hardware Design OS tutorials
  • Subscribers 365 subscribers
  • Views 999 views
OS tutorials
mindaugas
mindaugas over 8 years ago
I'am very intrested in running Android OS on ultra96 board. I would like to ask if there is going to be any related tutorial on how to build Android OS for ultra96. Also same about linux. I know there is a premade linux image, but I would like to know how to build it myself. Thank you
  • drozwood90
    drozwood90 over 8 years ago +1
    Hello there, There are currently no plans to port Android for Ultra96. To learn how to make a PetaLinux image, you can take our PetaLinux Speedway. This will help you gain the skills needed to do this…
  • drozwood90
    0 drozwood90 over 8 years ago
    Hello there,
    To learn how to make a PetaLinux image, you can take our PetaLinux Speedway.  This will help you gain the skills needed to do this.
    http://zedboard.org/support/trainings-and-videos
    "Integrating Sensors on MiniZed with PetaLinux (2017.1 and 2017.4)"
    --Dan
  • mindaugas
    0 mindaugas over 8 years ago
    Also I would like to ask then using original out of the box SD card with Linux OS can I connect to board through uart1? (uart0 is used for bluetooth) Becouse when connected I couldn't see any activitie like uboot messages or Linux kernel messages
  • mindaugas
    Also wanted to share link to quick tutorial how to build PetaLinux for ultra96 board. https://www.hackster.io/adam-taylor/two-methods-of-building-petalinux-for-the-ultra96-77c8e0
  • drozwood90
    Hi there,
    Ensure you follow the quick start card's instructions for setting up your Serial terminal program.
    --Dan
  • raiatea
    0 raiatea over 8 years ago
    Hello, I have seen there is a free Android for XilinxRegistered ZynqRegistered UltraScale+Tm MPSoC by Mentor Graphics..
  • drozwood90
    Mindaugas,
    When you build PetaLinux, ensure you choose UART1 for STDIO.  That is the UART used for serial terminal.
    --Dan
